DAC driver issues with Windows 11 - remedies and fixes?
Yachats
It appears that Windows 11 updates are interfering with a number of DACs and Microsoft's lack of concern is worrying. I just purchased the SMSL Raw Pro Dac 1. It took me about 8 hours to find the right driver (found a link on this website) and get my Windows 11 laptop to recognize the SMSL. Then another update occurred yesterday and Windows 11 cannot find the unit. I've downloaded the driver and installed it but it is not being recognized by Windows. I began searching to see if others were experiencing problems and these threads in the Windows forum popped up:
Unfortunately, the fixes suggested are above my pay grade. What happened to Microsoft's "plug and play" philosophy? Absolutely maddening.
It looks like I'm being forced to return my SMSL DAC and find another way to listen to my library of digital music. I hope there are some wizards on this forum that have an idea of what is going on and how to create a workaround that doesn't require a degree in computer science.
Thanks!
Windows 11 should be able to recognize the DAC plug-and-play, without ever manually installing a driver.
Please check in the Device Manager under "Video, sound and game controllers" if the DAC appears there when plugged in.
If there's an exclamation mark next to it, right-click -> uninstall device -> plug the DAC out -> restart the laptop -> plug it back in -> wait for Windows message "the device is ready for use".
I wouldn't even both with manually installing SMSL's custom driver unless you need a native ASIO interface.
Otherwise, Microsoft's generic plug-and-play device driver works just fine and causes fewer issues.
Microsoft have struggled with their USB implementation since the introduction of USB in Windows 95 OSR2.
Even though many things are supposed to be plug and play, that's not always the case even with Windows 11.
If their USB implementation was that successful, utilities like USBClean etc. wouldn't need to exist!
I wish it were that simple. When I plug the SMSL into Windows, it does not see or recognize the unit. It only recognizes the laptops internal speakers and microphone array. The SMSL DAC is just not there. I've also tried your recommended course of action, but to no avail. Thanks though!
Does the device manager flicker/refresh when you plug in or unplug the DAC?
You might consider trying different USB ports or cables.
Try installing Equalizer APO (and also PEACE), the EAPO configurator recognises DACs attached to USB ports really well,
you can then choose that as a "speaker" option, has worked for 5 or 6 different dacs for me, seems to recognise the chip
Just on the off chance, have you tried a different USB port at all?
If the issue reoccurred after an update yesterday, then clearly it's not related to the January updates.
Maybe roll back the last update and prevent it from reinstalling... open settings>windows update>update history>uninstall updates. Look under windows for the most recent KB installed just before your DAC stopped working. Right click and uninstall it... reboot.
Problem is Windoze will try to download that KB update again eventually... so if you use this old Windows tool;
You can then select that KB and hide the update, which should stop it from installing again.
JSmith
Thanks for this suggestion. I did change ports and I followed the advice on this article:
I specifically followed the advice below from the article as well as changing the port for the DAC and IT WORKED!!! I'm now listening to music via the SMSL. I want to thank everyone for their helpful suggestions. Hopefully this thread will help others if they run into similar driver issues!
1. Restart Windows Audio Services​
A quick reset of Windows audio services often clears temporary glitches:
  • Press Win + R, type services.msc, and hit Enter.
  • Find Windows Audio and Windows Audio Endpoint Builder.
  • Right-click each and select Restart.
This often resolves audio output failures after DAC detection or update problems.
