I read somewhere about the ZERO "inverting polarity": do the Zero:REDs preserve the absolute phase? Are they non-inverting?Truthear x Crinacle Zero:RED Measurements
When the cables of the Red/Blue are plugged in the right way, will the molded "L" and "R" on the connectors be on the same side as the red/blue shell? I assumed so when I connected my Reds, but the instructions were not clear about this, if I recall. Thanks.I only have the blue ones, you can make them invert, if you plug the cable ends the wrong way round (which is possible).
Such are sometimes the origins of "urban legends", maybe someone just didn't RTFM before connecting the cable?
The cable's ear hooks already dictate the way it's supposed to be plugged in:When the cables of the Red/Blue are plugged in the right way, will the molded "L" and "R" on the connectors be on the same side as the red/blue shell? I assumed so when I connected my Reds, but the instructions were not clear about this, if I recall. Thanks.
see @staticV3 post above, BUT, if you plug both wrong, they can be "almost right", then left is right and right is left, and the phase is wrong tooWhen the cables of the Red/Blue are plugged in the right way, will the molded "L" and "R" on the connectors be on the same side as the red/blue shell? I assumed so when I connected my Reds, but the instructions were not clear about this, if I recall. Thanks.
What test?A simple phase test clarifies the situation, if you're in doubt.
What test?
Hi! Does anyone else have the problem of the eartips slipping off and being stuck in your ear canal when taking the IEMs out? Couldn't find anything quickly in this thread or the ZERO one about it... It's quite annoying, what to do about it? I've only had both zero and red for 5 months now...
Yes. Does that make a difference?Do you use narrow bore tips?
Yes. You can revive the tips grip on the nozzles by briefly submerging them in near boiling water.Hi! Does anyone else have the problem of the eartips slipping off and being stuck in your ear canal when taking the IEMs out? Couldn't find anything quickly in this thread or the ZERO one about it... It's quite annoying, what to do about it? I've only had both zero and red for 5 months now...
Thanks, I didn't know that. How briefly is briefly? 30 seconds?Yes. You can revive the tips grip on the nozzles by briefly submerging them in near boiling water.
Zero Red is an easier EQ than Zero Blue, so that's a positive, with biggest difference being the amount of bass EQ required - however Oratory has decided to match the curve down to 10Hz rather than 20Hz which has mean giving the Zero Blue a +10dB bass boost vs only a +5dB bass boost if aiming for 20Hz. I'm thinking it's only necessary to target the EQ to 20Hz in which case he's doing an extra +5dB of unnecessary bass boost on the Zero Blue. Not sure if that extra bass boost could be detrimental to the Blue, my experience with boosting open backed headphones down to 20Hz rather than say 35Hz seems to be detrimental to aim for 20Hz if you need to give large bass boosts in region of 10dB. I'd be a bit careful with the EQ on the Zero Blue and instead modify his EQ to target Harman down to 20Hz rather than 10Hz. This is not a problem on the Zero Red - a very easy EQ on that one even down to 10Hz.Oratory1990 posted PDFs for Zero and Zero:Red
https://www.dropbox.com/scl/fi/uflm...Zero.pdf?rlkey=6col9lc2z9i6fcpv6seub76o8&dl=0
https://www.dropbox.com/scl/fi/m3bg...1990.pdf?rlkey=5g93mvqtptj2egrjf881vqgjf&dl=0
https://www.dropbox.com/scl/fi/t7tx...-Red.pdf?rlkey=izx7e2bn8zc9oeb6s2wvtxhur&dl=0
https://www.dropbox.com/scl/fi/gn2q...1990.pdf?rlkey=f0foxc74n0oa03f3fv568np61&dl=0
