Thank you for measurement. Does it work well in bypass mode?Do you mind checking what's the voltage of your power supply (is it 52V as well ?)
I get slightly higher temp from PA7plus, same room temp (25°C) and several hours of listening, low to moderate volume. See top and bottom case temp in the attached pics below (amp sitting on a custom build pair of NC250MP monos)
View attachment 292416View attachment 292417
I'm really curious because I'll be using the pa7 in an E70 + L70 combination.
