Topping PA5 fix - D01 Module Replacement for everyone
ive posted a guide on how to order pre-assembled pcbs on jlcpcb on page 2
just open the other design in the editor at the exporting step
Wov....you are great! Thank you so much!
topping appears to be offering (and I received mine) a free pa5ii for people with busted pa5's.
They will charge you $20 (payable via paypal with international fee) for shipping if your warranty is expired. You use your old power supply, which is the same as the pa5ii plus power supply.
edit: someone pinged me asking how I did it, I just emailed [email protected] and asked if I could get a replacement and they said yes. Just had to send picture of my serial and of the destroyed pa5. (I enjoyed the hell out of that part)
Destroyed, as in you had to show you had hit it with a hammer?
If they're following the same model as the early L30 replacements a hammer would do. Others drilled holes through them. Anything to make sure it doesn't work and couldn't be sold on eBay or similar.
Dear all,
I got a similar offer for replacement of my two PA5 units.
Are there forum members who can confirm, that the delivery of the replacement units was done reliably?
(which is approx delivery time?)
That is not meant to offend Topping company, but I would not like to destroy my partially working PA5 units and then get no replacement.
Destroying the units is hard enough :)
~eichhofener
Dear all,
~eichhofener
The replacement worked well for me. (I’m in the mid-Atlantic, US.)
I initiated the RMA in late January, sending them $20 via PayPal.
They were out of stock on the black units so that delayed things a bit. As I recall, total turnaround time was around three weeks.
Topping requires you to destroy the old amps. For some, I guess that may be satisfying.
All in all, $20 plus an hour of my time beats a $300 doorstop sitting in a box collecting dust. And for me, it also beats paying $50 for one of the reverse-engineered D01 boards and the ensuing disassembly, desoldering and module replacement which presents a number of opportunities to screw things up, though I do appreciate the effort to fix Toppings mess.
To be honest, I took the plunge about two years ago and bought an Audiophonics, Purifi amp so my Topping hasn’t seen much use in quite a while. (One of my friends may end up with a nice gift in the not-to-distant future!)
Reactions: MAB
So how did you destroy it?
With glee!
A drill, a pair of pliers, front wheel of your car, gasoline. Be creative.
Topping asks for photos of your work so throwing it off a cliff probably isn’t the best idea though it might be very fun!
Reactions: MAB
A camera with a small telephoto lens, e.g. Canon 1200mm, would help with this ;)
I can report that the replacement worked very well for me, too.
Topping sent out two PA5 II immediately after I emailed photos of the destroyed devices and after I transferred 40$ (=2*20$ obviously) via PayPal.
The turnaround time was 7 days!
I did the repair of two PA5 before seeing that they can provide replacement even for expired warranty.
Still thinking should I still go for the support for replacement or not.
Seems PA5 II still have blobs inside and the replacement module is a more permanent fix.
(I ordered 5 assembled PCB from JLC, still have three spare)
no failures of PA5 II reported so far, the heat source (opamps) have been moved outside those potted blocks
i also got 10 modules left if anyone need some in future.
too bad people throwing out those destroyed pa5's, even with a drilled trough pcb, everything is fixable.
In fact, the old PA5 has slightly better measured values than the II. For the circuit used, the spatial separation of the op amps is very important, and this is a matter of a few millimeters.
If I had the choice, I would go with the old one.
However, the II also has RCA inputs.
how? they took 90% of TI's reference circuit from the TPA3255 PFFB integration manual and tweaked the values a little
and its not exactly the same as for example in the pa5.
like "C24" comes after R7 and the PFFB line, not before as in the patent. but this is for tpa3255,
and their circuit is based on a dual-rail supply, not a VCC/2 floating ground single supply so two extra components are missing.
their patent probably is for a different kind of amp design
maybe you didn’t look closely. The board is only the left two op amps circuit plus the two pole compensations wrapped around the class D in the patented circuit. Board has 4 sets of such circuit.
Compare closely the parent circuit with the board schematic on the first post.
Of course it is slightly adjusted for the use case (3255) but the key idea is the same. Look at all the compensations around the left two op amps.
I'm curious as to how they were able to patent that design (if in fact they were granted the patent) if it was common knowledge already.
This isn't a patent, just a utility model.
These are usually granted without extensive or in-depth review.
Many of them aren't even legally enforceable.
But without the appropriate values, this is only 10% of the work.
