Vreek Fonq
And what is this?
Good eye!And what is this? View attachment 444474
From the review:You made me read it one more time and I stillI don’t see any mention of the OS mode that was active at the time measurements were taken. What am I missing?
With default filter, there is still some out of band noise to reduce performance but impact is low:
Go to "non-oversampling" mode and ultrasonic noise shoots through the noise, causing that off-the-charts green line. Best not to have a tweeter that attempts to go above 20 kHz!
You do have a really good eye!Being a photographer by trade, taking by the amount of reflection and highlight crush, I suspect it to be metallic in substance.
cs43198 does not have FFT functionality. It's there to generate the playback signal in full amplitude, which you cannot get from the DAC output as user may mute or use volume control.The CS43198 is used to render the FFT display, apparently: https://youtube.com/watch?v=myeVh77xedk&t=180
Looks like a solder ball. That can happen if too much solder paste is laid down onto the PCB traces in the kiln-heated soldering process.And what is this? View attachment 444474
Better picture here:Looks like a solder ball. That can happen if too much solder paste is laid down onto the PCB traces in the kiln-heated soldering process.
Whatever it is, it looks like it’s shorting two pins of the IC.Better picture here:
Looks more like a brass fragment, perhaps from a mounting screw?
