Or the Topping D10 Balanced.A DAC with XLR to SP200 should solve noise issue. Schiit Modius (maybe look used market too?) or sure, SU-9 will be good.
Yes.Based on these measurements, I should be able input 4 Volts Balanced from a DAC INTO the L50 and get 5 Volts / 1.25 Watts Balanced OUT into a 20 Ohm load in High Gain without audible noise or distortion right?
Another question, even though the output voltage of the DAC (4 Vrms) is greater than the input sensitivity of the amp (2.7 Vrms), the audio will only clip or distort in high gain if I exceed 7 Vrms right?Yes.
To be safe say it's 7 Vpp which is just a tad under 2.5 Vrms. If you are worried about over driving the amp you can switch to the medium gain. I've got one along with the E50 DAC, it sounds great. Of course they all do but, in combination with a good DAC such as the 50E you will not hear any noise.Another question, even though the output voltage of the DAC (4 Vrms) is greater than the input sensitivity of the amp (2.7 Vrms), the audio will only clip or distort in high gain if I exceed 7 Vrms right?
O Ok Thank You very much for the reply.To be safe say it's 7 Vpp which is just a tad under 2.5 Vrms. If you are worried about over driving the amp you can switch to the medium gain. I've got one along with the E50 DAC, it sounds great. Of course they all do but, in combination with a good DAC such as the 50E you will not hear any noise.
I should lay my cards on the table at this point; I know own a RME ADI-2 DAC/Headphone amp. I prefer the RME over the E50/L50. It's nothing to do with superior sound. To me both the RME and the topping combo sound the same and because it's the more recent design, the L50 may have the better specs.
I just like the user interface on the RME I'll be the first to admit it's hard to justify paying twice the the price of the E50/50L for nicer knobs and a better menu, so I won't. Well it was on special, it's normally two and a half times the price!
What is the signal source for the L50? Maybe it needs to be in the medium gain mode.When driving Hifiman HE400SE, with High gain setting and passing 3/4 of volume pot rotation, after second of two Topping L50 is shutting down, and LED status diode is blinking instead of being constantly lit. Then I need wait some time for it to get back to life, no matter whether I replug power to unit or not.
My uderstanding is that there is some kind of protection circutry kicking in?
PS. This is by any means how I am listening to music, rather testing whether they can be a loudspeakers
Topping E50 through balanced.What is the signal source for the L50? Maybe it needs to be in the medium gain mode.
I think you're pushing about 2.5 watts into them. So the l50 is hitting clipping and thermal overload. Probably best to back off before either the amp or headphone gets damaged.Topping E50 through balanced.
Dont get me wrong, I know that I am pushing it far beyond regular listening levels. For listening I am using mid gain and volume pot around 12 o'clock.
My only question is whether should I worry that there is something wrong as unit should work all the way to the end of volume pot scale or its just matter of internal protection of unit itself (hot balanced input + high gain + low impedance/moderate efficiency headphones).
If the Head Phones were a straight resistive load the protection should not kick in but, it will be a reactive load which is harder for the amp to deal with. It is also likely the headphones are being driven into a non linear region which will reduce the impedance and increase the current.Topping E50 through balanced.
at 2 U"ll have better L/R matching , even if 10 is (on my unit ) yet OK ... the sound is different , hi gain (i suppose) uses an op amp to amplify the signal .. on mid not , neither on low , just added resistors before the volume potentiometer , so (theoretically) mid is better , but judge Yourself what do U prefer.Question regarding gain settings on this amp. Would it be better to run medium gain at 2 o'clock or high gain at 10 o'clock?
I'll see in a week what"s what , however , even if it happened (flashing) even if I did like U suggest , today all is working properly .The blinking light occurs if you turn off your system while the L50 is on. Turn off the L50 off first before you turn off the rest of the system. Then when you start up again, it won't happen. At least this was my experience with the L50.
Hi. Does the L50 have identical power output if it is used in pure single ended configuration (rca input + single ended output) compared to its (XLR input) setting. I have a Topping E30 and a Magni 3 and I am looking for an amp for more power via (single ended input + single ended output) for my Sennheiser hd 650. I am planning to buy L50 but I am concerned regrading any decrease in power output if it is used in (single ended input + single ended output) with a dac like E30. I don't really want to buy L30 as L50 has more power. So I would like to know what is real power output of L50 in (single ended input + single ended output) at 300 ohm load.This is a review and detailed measurements of the new Topping L50 balanced (input) headphone amplifier. It was sent to me by the company and costs US $229. It will be announced shortly.
The industrial design of the L50 is different than older models with a plexiglass front:
While I like the red accent on the volume control knob, the contrast is low on the labels to read them easily. There is a plastic cover that has duplicate labels on it which are more legible. Fortunately there is not a whole lot here to remember as to need the labels.
The back side and power supply show more of a departure:
Instead of the usual switching power supply we now have a beefy AC transformer. As I have noted before, AC input makes it easier to generate positive and negative rails for the amplifier so I can see the motivation. Then again, the transformer is inefficient and quite large.
Up on top you see a connector you don't normally see on a pure analog amplifier: the USB-C for firmware upgrades! A supervisory processor handles protection which can be reprogrammed as needed. Indeed, during testing I pushed the unit hard with 12 ohm load well into clipping and it shut down with a sequence of LED lights. Once it cooled a bit, it enabled the device to function again.
The other change which we have seen recently from Topping is use of 1/4 inch input for balanced interconnections. They take up a lot less space than XLR so you can have the same rich set of connectivity including pre-amp in this small enclosure. 1/4 balanced is extremely popular in pro audio so there is plenty of cables and adapters for it if you are not situated currently to use them. And I believe a set of adapters come with the unit.
Topping L50 Measurements
There are many combinations here to test so I limited the input to balanced but measured both balanced and unbalanced headphone output. Let's start with balanced input:
And now RCA In:
Exceptional performance yet again, almost in the top position of our rankings for SINAD:
Here are our noise specs which are stellar:
This is what great SINAD does for you at the top of the class: incredibly low noise where you need it with sensitive IEMs:
Anyone who says SINAD is not important doesn't understand this dynamic, pun intended.
Frequency response is flat of course to beyond what we need:
The main business of a headphone amp is producing power though to drive more difficult headphones. So let's test that with 300 ohm load:
My standard for power output is 100 milliwatts and the L50 sails way past that which is great.
Let's switch to other extreme with 32 ohm load, emphasizing current delivery as opposed to voltage:
This is a ton of power coming out of this little box.
Sweeping the load and measuring power we get:
The main difference here compared to bigger brothers is that it clips with higher impedances whereas they don't. Up to nearly 7 volts there is no load dependency.
Finally here is our channel matching which is excellent for an analog control:
As usual your mileage may vary.
Listening Tests
Surprise, surprise, the L50 aces my subjective tests. What can I say. Whether I used the Sennheiser HD650 or Drop Ether CX, there was incredibly clarity, detail, authoritative bass, etc. My ears would scream before the amplifier even got barely unhappy as far as volume.
Hit after hit is the expression that always comes to mind when testing Topping products. Engineering done properly would be another saying. Compare this to many high-end products which barely get verified at all to see if they are what they think they are (transparent and well engineered). We do have some departure in form factor and functionality most of which are positive in my view. You get more choices and more to decide.
It is my pleasure to recommend the Topping L50.
Note: I have no commercial connection of any sort of shape with Topping or any other company for that matter. Don't spread rumors otherwise or I will personally show up and whack you in the back of the head! Many companies send me products and when they perform this well, they get my accolades.
