Hi,
I purchased a Verum 1 HP, which is rated around 7 ohms. I use it in a home studio environnement where I need a pretty neutral/analytical sound. When I plugged it I to my interface (Presonus 1824c) I found the sound a bit unimpressive, lacking in bass. Checking the 1824c specs and reviews, I found that it's HP output has a pretty high impedance, which could point to a mismatch with the Verum 1.
S, I purchased a Topping L50 which looked to fit the HP needs, or it was my impression. Unfortunately the L50 quickly failed, or maybe it's just the AC/AC power brick but I can't test the amp with another adapter as AC/AC is hard to find (going to return the unit to Amazon).
My questions are:
- Was I just unlucky with that unit, or did the 7 ohms impedance HP draw too much current for that power supply, or something like that?
- In this case, should I purchase another, more powerful, HP amp?
- would something like the Topping A30 pro, SMSL SH-9, be better suited?
- Something else to consider below 300$, preferably with balanced input? (The TRS I/O passthrough of the L50 was really cool for my studio setup).
Thanks for reading.
My questions are:
Thanks for reading.
