a suggestion ....
i would rate these power supplies from mean-well
in general they are used for medical applications, therefore excellent products at very low prices
MEAN WELL GST18A05-P1J AC-DC High Reliability Industrial Table Top Power Supply, 2.1mm Plug Level VI, 5V 3A 15W 3-Wire: Amazon.com: Industrial & Scientific
www.amazon.com
This will hardly bring you any benefit, many SMPS for the medical field are even worse suited for audio applications. It's more about durability, protective mechanisms, voltage stability, insensitivity to external influences, efficiency, etc. Particularly low noise or ripple are quite unimportant because they are intercepted in the devices.
Mean Well has a couple of very good industrial power supplies as an open frame or in a perforated sheet metal housing with very good values, but you should only approach them with the necessary skills.
In Germany/EU you can often find very good power supplies for little money at remaining stock electronics dealers, e.g. Pollin.
But take a look at the filter module for SMPS wall warts from the DIY neighboring forum, that brings more than any new power supply.
