tvrgeek
I did use a USB-3 hub after the isolator. That is how I put power to it. Cables are all less than one meter. Isolator was plugged into the computer directly.
I am currently using the KTB with my Atom Amp.
What are you using? Foobar? Thank @solderdude for this - https://diyaudioheaven.wordpress.com/digital/pc-software/foobar-2000-for-dummies/I like to get what I paid for. "Those measurements " gave me almost an order of magnitude improvement.
I have still not found any functional information on what can, or how to implement ASIO or WASAPI. Mostly on recording tool specifics. No good primer on the whole picture. Borrowed a book on "Entertainment Apps" it's most complex comment is "run groove to play music" and then says to pay Apple for songs.
At the risk of repeating myself, your DAC does not implement ASIO or WASAPI - this is the SOURCE!!! In order to use ASIO you need to have the drivers in place, but that it a software not a hardware issue. Many players (Foobar being an example, but also much simpler ones such as Music Bee) have the option of WASAPI.or how to implement ASIO or WASAPI. Mostly on recording tool specifics. No good primer on the whole picture.
Just used Paint.Net with the .ico plugin. Just selected the resulting file in a folder, no need to point to DLL.how did you add the icon and to which dll file?
Review says the price, conclusion a little uncertain. But after 160 pages, is it worth it? Is there anyone that doesn't know about the device and its price?Hey @amirm, can you edit your conclusion.
It feels a bit incomplete as at the time of writing you weren't aware of the pricing it seems.
Thanks
Thanks
When the review was first written, the price was not yet known.What I meant is the conclusion
"With my assumption that this is a mid-priced DAC, I am happy to add Topping E30 to my recommended desktop DACs."
Is on an assumed basis. Hence I just suggested that it could be more clear for new users.
