(I need to do some cleaning... Dust everywhere.
Got it up and running. I hear absolutely no difference between it and my AE-5 which was excepted. Or if I would put it differently, it doesn't sound worse. This is good since it means I can't hear any noise and stuff like that i.e. sound clean (unlike my display or laptop). I can finally get proper sound when using my work laptop at home. My O2 is probably the bottleneck anyway.
I wish the Windows volume control would be "wired" to the DAC (when using USB) like it is with AE-5. It would definitely require custom driver (haven't installed one and not going to if the only benefit is ASIO driver). Currently using the DAC mode and controlling the volume through Windows 10 since I don't have batteries for the remote control yet -_-. I'll have to be careful to not use WASAPI exclusive mode...
And when it comes to "Velvet Sound" vs. "Sabre glare"... It's all utter bullshit assuming the implementations are even half decent (it certainly is possible to ruin every DAC with incompetent engineering) and used filter even somewhat similar.
Hifitalo in Salo has them.Then I have to send my mom to FinlandShe's Finnish and can travel in these Corona times.
