Optical / SPDIF and Jitter measurements what can be audible to a perfect human ear with a clear mind and healthy level brain function ?
Earwax
Vancouver, Canada
I`m Researching the Topping E30 II lite and after reading and comparing the optical jitter measurements against the SMSL SU1 and Topping DX3 Pro plus there is a noticeable difference in the measured readouts..
What exactly are the jitter measurements is it harmonic noise that will have an effect musical harmonics ?
After only reading research, it appears to land on the fact that it will affect musical harmonics probably the finer more delicate possibly by adding to them altering them. ?
What is the acceptable level of jitter before it has any influences on delicate harmonics ?
images are from this forum,
Thank you for your time and assistance it is much appreciated !
From what I've read jitter has to artificially generated to make it bad enough to be heard. Then it sounds like noise.
To add on to @DVDdougs comment, real life jitter is almost always way too low to hear and mostly sounds like noise if you amplify it.
There is such a thing as correlated jitter which sounds pretty awful, but I'm not aware of any devices that have that problem IRL.
Jitter may have been a problem 30 years ago.
Unless you own a TV with digital outputs that have jitter bad enough that you're losing signal entirely (*cough*LG*cough*), it's really not something to worry about.
In the review you took that chart from the reviewer states "not likely to be audible though"
There is your answer.
Likely is a definition of absolute fact ?
That's why I'm researching what level of jitter is not great....
Opinions are helpful but at times they just beat around the bush.
Here is a jitter experiment I found. I'm sure you can find more.
Just scanning the article I didn't see an "answer" but you listen for yourself. With all of these types of experiments, it's going to depend on the listener and the nature of the audio so I doubt there is a single-solid answer.
...I NEVER hear ANY "digital problems" unless it's a low-resolution (lower than CD), or a low-bitrate MP3, or if there is gross corruption or dropouts, etc.
Most problems are on the analog side, particularly speakers and acoustics.
