It would be an extension for your existing USB A to DC cable.Wdym DC female to DC male? where would the power source be if not the computer port with USB-A?
Also would connecting it to an USB Hub have any downsides? How much size does it take?
Delock make good quality USB cables at a low price: https://www.delock.com/produkt/84896/merkmale.htmlI need a longer DC5V to USB A and USB 2.0 Type B to USB A to connect them to my computer since the cable length for the ones that came from the manufacturer are too short. I just want to confirm those are the right type of USB connectors and is there any recommended brands for those cables to purchase. I need at least 6 FT I believe. I bought a standing desk so I need it to be long enough to be able to go to standing height while connected to the computer.
Please answer the question yourself. Millions of these extension cables are sold worldwide every year. How many fires have you heard of?Ok, I understand now for the extension, that is safe with no risk of fire hazard with that type of connection vs just a longer version?
Was looking at one of these 4 or 7 port USB Hubs. I know when connected to an USB 3.0 port, everything connected to the HUB would be bottle necked by the port itself of 5 gigabits. I am not sure how much data speed the E30 needs without any loss in audio quality.
That approach is known as survivor biasPlease answer the question yourself. Millions of these extension cables are sold worldwide every year. How many fires have you heard of?
My post referred, among other things, to the millions of security/surveillance camera installations in the EU, where these DC extension cables are used as standard. Apart from contact problems and defective cables, I'm not aware of any other problems.That approach is known as survivor biaswhen it comes to questions of regulatory compliance.
I don't know the answer either, and am also curious.I'm not aware of any legal regulations in the EU regarding DC cables in the low-voltage range up to 24 or 48 volts. The same applies to small-signal cables such as RCA, XLR, or USB cables. USB-PD, for example, transmits up to 48 volts and 240 watts of power.
If you have other information on legal regulations, I'd appreciate it if you could share it.
There are several DC cable sizes, I emailed topping and its been over a week and have not gotten a response to what size the barrel is, do you happen to know?It would be an extension for your existing USB A to DC cable.
If it's an active hub, the E30 shouldn't mind. But how do you come up with a HUB?
I think 2.1 x 5.5mm, but I can't say for sure until I get home this evening.There are several DC cable sizes, I emailed topping and its been over a week and have not gotten a response to what size the barrel is, do you happen to know?
2.1 x 5.5 mm is correct.There are several DC cable sizes, I emailed topping and its been over a week and have not gotten a response to what size the barrel is, do you happen to know?
Thank you!2.1 x 5.5 mm is correct.
Sounds like you fried it.I accidentally plugged the Amp's cord into the Dac and it started to display "E-2" on the screen. Then when i switched it back after realizing my mistake, it now says "E-5" and won't work anymore. Did I break my DAC and need to get a new one?
Probably. If you're lucky there's some sacrificial component that's easy to replace locally. It's probably a question to direct to @TOPPING or their support email as they will know exactly what the error codes mean.I accidentally plugged the Amp's cord into the Dac and it started to display "E-2" on the screen. Then when i switched it back after realizing my mistake, it now says "E-5" and won't work anymore. Did I break my DAC and need to get a new one?
I was thinking I did, makes me wonder why they dont have over-current protection considering this is meant to be a stack.Sounds like you fried it.
Thanks, I'll reach out. I bought this second hand so I don't expect them to be able to do anything, it's more of can I salvage it or find a new one, or just upgrade at this point. I can't find any red e30s on eBay so if to replace it I'm going to have to mix colors.Probably. If you're lucky there's some sacrificial component that's easy to replace locally. It's probably a question to direct to @TOPPING or their support email as they will know exactly what the error codes mean.
You could also simply replace the circuit board with a different color.Thanks, I'll reach out. I bought this second hand so I don't expect them to be able to do anything, it's more of can I salvage it or find a new one, or just upgrade at this point. I can't find any red e30s on eBay so if to replace it I'm going to have to mix colors.
Or swap the internals over.I can't find any red e30s on eBay so if to replace it I'm going to have to mix colors.
