Right now I have an X26 Pro (Black) and a D90LE (Silver) at the same price.
I have an A90D in silver so I was trying to figure out if I should even consider the X26 Pro if I can't hear the difference between the two.
Based on my readings/searchings, one can't be different than the other in an audible sense correct?
From what I understand and speculate, the people saying X sounds better than Y is due to an imbalance of dB when flipping between X and Y where our ears perceive an acoustic property change. For example, If I want to feel a specific slam on a note or "clearer" I'd raise my volume knob a bit.
I understand that EQ is doing the same thing but that would be processed through the entire track rather than when I volume DJ, it is only for those increments of dB.
EDIT:
I'd ideally like to stick with the same colour theme, ergo the X26 Pro vs D90 situation.
This stemmed from people raving about R2R dacs and the May/Spring vs other DAC's.
I know R2R can sound different (I assume with my limited knowledge) is due to the slight distortion it may bring to the table?
In theory, the Holo May, the cleanest R2R DAC should sound similar to the D90LE (Or whatever is the best measuring DAC out there) right? or am I misunderstanding?
I like this video: Holo May review
Have fun watching it
Personally, I decided to buy D90SE because it is perfectly consistent in terms of jitter across all inputs, and it nearly perfect in all other aspects of measurements.
I think this is quiet an achievement by its developer, especially in the attention to detail.
That's why I like it.
