Topping D70 Pro Sabre DAC Review
Rate this DAC:
    Votes: 6 1.7%
    Votes: 12 3.4%
    Votes: 46 13.2%
    Votes: 284 81.6%
Has been available in ESS Sabre-based DACs for a while now, though.. :)
I'm very interested in which other DAC offer this specific functionality. Maybe this is the first time I'm seeing it marketed this way but it strikes me as something new vs other filters that didn't explicitly call out the 2nd, 3rd, etc harmonics elevation. I've looked around a bit since seeing this on the D70 Pro and reading this thread but haven't found anything I can confirm to be the same.
If anyone can point me to other DACs that offer this, I'd be grateful.
Thanks.
Thanks.
I believe all Topping DACs which use Sabre PRO chips (so more premium segment) have these characteristics to be enabled but best to check the manuals to be sure.
Also SMSL DACs do something similar with 'sound color' settings when they have that available, but it's less well documented what they do..
Does anyone know if Topping has solved its remote control issues with the D70 Pro? I have bought and abandoned the Pre90 (for an Eversolo DMP-A6 and the superb bluetooth remote) due to its lack of usability on this front.
How to connect a subwoofer to this DAC ?
Should I use 2 rca cables or one ? The subwoofer has 2 RCA inputs. Can I use one cable?
I own the D70 pro and use a Topping RC-22 remote. I don't know wether it is better than the stock remote, but as far as IR remotes go it's very responsive. As with all IR remotes line-of-sight is rule number one.
Reactions: GPJ
Thanks Bob101. Do you have a rough idea of how many degrees you can go off being right-angled on the dac for the remote to work? On the Pre90 I would guesstimate I have roughly 10-15 degrees off-angle on either side before the remote becomes unresoponsive.
In my setup the remote reliably does the job over +/- 30 degrees off-axis both horizontally and vertically. That's a nice window IMO.
My D70 Pro Sabre surprisingly bricked within the first 3 weeks. Luckily it failed during my return window.
Hello,
I am new here, good too see you all.
Need info, what is the main differences between Topping D70 Pro Sabre VS Octo ? is that only chip?
which one have better sound quality and feature?
thank you
Hello,
thank you
For all intents and purposes the only difference is the DAC-chip(s). Nobody can tell these apart in a blind test. All the rest is identical. According to Topping the octo even measures a few dB better here and there. Both DAC's are way beyond transparent. Unless you really want a Sabre, the octo is a little cheaper...
I you can live without the fancy interface: there's the E70 for you, for just about half the price.
Hello everyone, I'm new.
Since a couple of weeks I bought a D70 PRO + A70 PRO.
When I'm not using my headphones, I use Eris Studio 5 + Eris Studio Sub 10.
The A70 PRO is connected to the DAC by XLR cables, then a couple of XLR cables connect the Eris Studio Sub 10 to the A70 PRO; eventually the Eris Studio 5 are connected to the subwoofer via TRS balanced cables.
I was wondering: are there any differences between connecting the subwoofer to the A70 PRO (pre-amp mode) and connecting the subwoofer directly to the D70 PRO in pre-amp mode?
I think the routing solution you use now is the most optimal. If you'd use the D70 as preamp you'd lose the balanced connection to the A70.
The difference in using the D70 vs the A70 as a preamp is that the D70 has a digital volume control, and the A70 has (a very good) analog volume control.
The measured performance of the digital volume control in the D70 wil be rivalling or outperforming any SOTA analog volume control, including that of the A70. That is for (channel) level-matching, crosstalk and SNR. Will you be able to hear that? Unlikely.
Many thanks for your detailed answer, I'm not that expert and trying to learning as much as I can from this forum.
Of course I wouldn't give up to XLR connection to A70, I'd swap them from monitor to amplifier every time I need to use headphone (of course this wouldn't be the better solution) :)
One strange thing that I noticed is that If I directly connect the Eris Pro Sub 10 to the D70 by XLR cables I have no crackling/distortion on the monitor with the monitor gain to 0 dB.
Once I use the full chaing (D70 -> A70 -> Eris Pro Sub 10 -> Eris Studio 5) sometimes I ear crackling sound from tweeter, for examples when I'm watching youtube videos or listening to piano song (FLAC 86 KHz). I have to set the gain to -5dB on the Eris Studio to reduce this crackling sound.
If I use RCA unbalanced connection from A70 to Eris Sub, there is no crackling/distortion from the Eris Studio Monitor.
Of course using unbalanced connection brings a lot of noise and disturbance in my particular case, so is not a possible way for me, it was just an experiment.
Any idea on the reasons?
Does this have any DPLL settings? Any issues with optical signal dropouts?
