Experience with Topping A70 Pro + D70 Pro Octo
Axel Endriss
Due to curiosity and the good reviews, I bought both the PreAmp A70 and the DAC D70 Pro Octo from Topping. Since I could imagine that others are also considering this, I would like to share my experience with it here.
Hoping for a sonic improvement over my current system. I'm quite happy with it, but why not if you can do better
My current system consists of a Raspberry PI5 with Allo's HAT DAC Piano 2.1/Kali as a streamer. I had an old Linn Wakonda as a preamp, Audiphonics HPA-S400ET as a power amp and Vocal Temptation speakers, also old but refurbished about 5 years ago, supplemented by a Nubert SM310 subwoofer. There's also a Linn LP12, but it's out of competition (especially as the A70 unfortunately doesn't have a phono input). I use Volumio as my streaming software.
First of all, the A70 arrived. It immediately scored points with its significantly increased transparency and spatial resolution compared to the Linn Wakonda. What is striking is how much clearer the difference is between the various resolutions. While up to now I didn't notice any significant gain with resolutions higher than 44.1/16, I now realized that it sounds even more airy and silky. 192/24 sounds much more like LP12 than 44.1/16.
Then the D70 Pro Octo arrived and I was very excited to see if it could be topped again. During the first test with my “small” system in the cellar (Raspbi P3 as streamer, Allo Volt+ D as amp and Elac Debut Reference DBR-62 speakers) I also found it “audibly” better than with the Allo Boss (V1.2) mounted on the Raspbi. However, I didn't make an A/B comparison there and the listening experience may also have benefited from the half bottle of wine I consumed on the side.
Today I made A/B comparisons on my “big” system, comparing the Octo with Allo's Boss. And what can I say, no matter what resolution or type of music, it sounded fantastic with both, but I couldn't tell the difference. Not even a nuance!
I think both the A70 and the D70 Pro Octo are very good products. However, since I can't hear any gain in the Octo compared to my previous DACs, I probably wouldn't buy it again. Of course, it would be interesting to hear how the Octo sounds in preamp mode connected directly to the power amplifier compared to the Octo -> A70 -> power amplifier setup. I will probably try this out too, but unfortunately an A/B test is hardly possible. If so, I will report on it
I have the Pi 3+ with the Allo Digione as media transport, currently into a Topping D50S into a tube amp outputting to Kef XQ40 loudspeakers.
I'm considering buying the D70 Pro Octo and a NCx500 stereo amp, a comparable setup to what you would be using if you took out the A70.
I'm very interested to know how your setup compares without the A70 included, and if you think the D70 Pro Octo offers a good value for that setup compared to the Allo HAT.
Hi Denios,
I still haven't done a listening comparison without the A70, but if I do I'll report back here.
In your case, the decisive factor seems to me to be whether the preamp part of the D70 offers audible improvements over the D50S topping.
Regards Axel
That and the option to use XLR interlinks to the amp I'm looking at. With the higher preamp mode output voltage of XLR, I can use lower gain on the amp and get the 'cleanest' sound while still maintaining a good bit of power reserve.
Hope you get around to the comparison sometime, I'll check back if you do.
Cheers!
I did a similar comparison and can say driving amps with lower voltage DAC isn’t ideal
AFAIK Mostly due to loss of bits IF the volume control is digital
Honestly you need a super revealing system to hear a difference on modern dacs
DAC is the last component you should invest in nowadays but if you have an old noisy and jittery DAC, this is a top replacement! Above this level, the Audible differences are negligible unless you have 200k usd speakers
Mostly if you find that some DAC sounds better I'd look into if it plays just a bit louder. And it's possible to have filter settings which are not optimal..
100% agree.
People forget it’s not only about output voltage — it’s about current delivery, output impedance, and the ability to swing and settle fast.
A DAC with digital volume control and a simple op‑amp output stage does not have the drive capability to act as a proper preamp.To make demanding speakers and a current‑hungry power amp perform (like a purifi class d amp to a pair of B&W 804D), you need a high‑quality analog volume control and a strong gain stage... Sure, if you’re running a small Fosi amp and $200 bookshelf speakers, DAC‑direct is fine. But with real speakers and a serious power amp? No — absolutely not.
In normal high‑end setups, amps, speakers, and room acoustics dominate the audible outcome.
Once you’re in D70 Pro Octo territory, DAC differences become extremely small — you generally need very resolving systems (think $100k–$200k speakers in a treated room) before DAC variations become reliably detectable. I agree with you that level‑matching and filter choice matter far more than the DAC model itself at this point.
100% agree.
More nonsense. You just got a thread closed for posting similar incorrect suppositions and misinformation.
