Topping D70 Pro Sabre DAC Review
Rate this DAC:
    Votes: 6 1.7%
    Votes: 12 3.5%
    Votes: 46 13.4%
    Votes: 279 81.3%
Hi everyone, I have been using that dac for one week. Is there any difference in sound quality between pre mode and dac mod?
My problem is; In dac mode, it is not allowed to change the volume but in pre mode, it is.
I use that dac with wiim pro network player and it has no remote.
Wiim pro has its own mobile application and it is not practical to use it in order to adjust the volume.
Do you have any advice to adjust the volume in dac mode? Or should i use it in pre mode?
My Setup: Homatics TV Box to TV (HDMI) - TV Qut to Wiim Pro (SPDIF) - Wiim Pro to D70 Pro Sabre (SPDIF) - D70 Pro Sabre To Focal Alpha Evo 65 (XLR)
im considering getting Topping D70 Pro Sabre is there any known issues with this device? because i don't trust topping qc
Great dac.:)
Some mild criticism :
Why implementing bluetooth ? This protocol has nothing to do with high fidelity, - it would have been really great If there was DLNA , Wi-Fi and Airplay compability.
But I guess one cant have it all for this price.
You could buy a raspberry pi and put Volumio on the flash card! It costs not much but brings you many cool features, like a huge radio streaming list, multiple music source options (local, SMB / NFS Share, etc), WiFi connection, etc. In my case, i bought this DAC knowing the measurements and putting money on that. I don't want to lower quality of the DAC itself at the expense of adding functions! But hey, that's just me!
Install Volumio 3.3 UNIVERSAL to create an Airplay streaming endpoint with a Raspberry Pi
How high can channel balancing go?
RTFM!
https://www.tpdz.net/newsinfo/838383.html
The 5 volt output from the balanced outputs is supported by all amplifiers or should be seen in the manual because nothing is reported on mine.
how much is the review of the new d90 to compare it with this one?
Amir delivers
@amirm or whoever can explain it to me please.
In some (older?) reviews, SINAD vs Volume Level shows on the x axis Vrms but in other reviews like for instance this one, the X axis is showing Time and there is also a 2nd Y axis. How to read this?
