GeekyBastard
- Joined
- Jan 27, 2019
- Messages
- 307
- Likes
- 678
This is absolutely crazy, $139? I couldn't imagine such price vs performance ratio even in my fever dream several year ago.
Signal to noise ratio is excellent:
Any possibility of opting out of the TRS balanced adaptors? I already have custom made starquad ones with Neutrik connectors
Corrected. Thanks.DSD356? Never heard of it, a typo?
Agreed, Adapters are included so you can use normal XLR to XLR or TRS to TRS, depending on which end you prefer to attach them, but that definitely adds bulk on the desktop systems this seems to be perfect for. I'm assuming case limitations are the reason, but that is just a guess.That said, I'd LOVE to have it with normal XLR outputs not to have to use custom cables.
There are Neutrik TRS to XLR adapters included in the box.DSD356? Never heard of it, a typo?
You can use normal cables.That said, I'd LOVE to have it with normal XLR outputs not to have to use custom cables.
I meant to leave them out, I don't need themRetermination is fast and easy. I like the TRS solution.
Corrected. Thanks.
Size? This thing is tiny.@JohnYang1997, why were TRS connections used?
