Time Domain measurements?
Trdat
Yerevan "Sydney Born"
Sure, you can make quite precise time domain correction, and it will look really nice with some FDW applied to the response measured from LP. But once you remove FDW reflections will make a mess of it and that is the reason why time domain correction is hardly audible in most of the rooms. Only if your room is pretty much reflection free you have a chance to hear the effects of time domain corrections and even then they will be subtle.
This is interesting, I removed my panels from the lateral reflections points in my room and now find it hard to discern switching between convolution and without. Although my listening room is heavily treated, perhaps the removal of the side reflections did make a difference in the audibility of the time domain correction.
Frgirard
Classical bias. I live this a each time i play with my room.
I measured and saw nothing.
ernestcarl
How about time domain correction in the bass -- let's focus in the xo interaction between sub(s) and satellites.
If one is able to measure a difference in the magnitude level after some pure time domain correction/optimization, I'm quite sure it's going to be audible regardless of the absence or presence of side-wall acoustic panels.
Vector average of bass-managed front and surround channels (x4) at the MLP:
Ignore above 300Hz -- the mic did not stay in the same exact position (as this was measured on different days).
If the difference is hard to see, below is an overlay with smoothing:
Range of interaction is very wide as I'm not adding any HPF to the satellites and the LPF of the sub is at 180Hz. Oh, and BTW, EQ is identical between the two.
I've done time correction in the bass where the frequency magnitude level is altogether exactly identical (except it is not if you apply FDW of 3 cycles, for example), and there I can still hear differences by switching between filters back and forth. But all major differences are seen in the time domain graphs, which pretty much directly correlates with the changes in what's heard with my AB'ing of test tracks/samples. IMO, the improvement is not merely because of a simplistic increase in the magnitude level, but it's is in the overall quality or "coherence" of the sound heard as well.
haraldo
West Norway
At the end of the day it is not possible to make a first order acoustic crossover over a wide frequency range. Thiel ended up with a 5 way in the CS5. You also run into problems with vertical lobing. In the Surveyor I use a second order acoustic Linkwitz Filter. That has the tweeter phase reversed. I ended up with only 6 parts in the crossover. Two parts can be switched out with a knob that you can set between Flat and Fast. Fast Switches out two parts in the crossover and then there are only four parts left. I will show measurements what that switch does. With Accurate from Dr. Brueggemann you can then easily compare if the phase response of the Surveyor is audible or not at a click of a switch.
Do you have measurements illustarting this @Joachim Gerhard
haraldo
West Norway
Trinnov does some things to phase indeed, here with Audio Physic Avanti III, before, after and the phase filter
dasdoing
Salvador-Bahia-Brasil
it would be much less confusing to use excess group delay plots to show time distorsions.
a constant delay will produce a slope on the phase plot, while in reality there is no phase distorsion.
and a room system corrected to a perfectly flat phase will in reality have huge predelay = time distorsion
haraldo
West Norway
Here it is :)
Group delay
Impulse response
ernestcarl
Here it is :)
Group delay
Impulse response
It doesn't really say if it's excess group delay that's being shown.
And unless one reviews the set parameters beforehand, one can't really know for sure what filtering is applied.
*Hopefully, listening tests were done after to check for pre-ringing distortion.
haraldo
West Norway
Not sure what excess group delay is v.s. group delay....
My experience of Trinnov with optimizer v.s. without. To me it is a life changing improvement :)
ernestcarl
Nothing
Difference between the actual measured (GD) and the minimum version according to the REW help manual.
I believe you. But others here who own Trinnov systems have said before that they heard "ringing" caused by overly aggressive corrections -- which is certainly possible if one tinkers with the default(?) filter correction settings without knowing what it could do.
thorvat
Excess GD = measured GD - minimum phase GD.
Minimum phase GD is calculated from measured amplitude response.
Don't bother with it, your GD graph looks fine.
thorvat
Are you claiming you can hear the difference between those 2? :D
haraldo
West Norway
I am not using default, I have close to zero correction above 200Hz, but there is still phase correction... I want to go further and have speakers that do not require phase correction, maybe even better.....
EDIT: I only use Trinnov x-over for bass management (subwoofer)
It's been previously stated by @Joachim Gerhard that Audiovero Acourate X-overs sounds clearly better than Trinnov
ernestcarl
In a properly conducted blind test or you knew which one you were lsitening?
The change in presets is not completely seamless since there is a delay and a slight disruption during playback in JRiver. I have posted ABX results in foobar before for my post linearization correction experiments. The difference are not subtle here in the bass xo linearization so a blind test is not even necessary.
thorvat
Most of the phase correction is due to the phase deviation caused by passive XO. Luckilly, those deviations are practially inaudible, at least in a room with "normal" reflections.
thorvat
When discussing such differences blind test is always necessary. Btw, check the related AES articles and you will quickly realise that practically no human being can detect phase correction of passive XO when listening in a "standard" room, not to mention such small phase differences as ones shown on your graph.
ernestcarl
FYI: correction shown in the graphs used active cross-over FIR filters. My room is (semi) treated.
But I can also hear passive xo post linearization corrections even with the mid to HF drivers of my smaller (non-linear phase monitors) in my room -- see attachments.
Doesn't matter to me if you believe any of my graphs or subjective listening test results.
  • TEST SET 1.txt
  • TEST SET 2.txt
  • TEST SET 3.txt
