I read through the Waxwing user manual and it seems like this could be used at the line level, so I have a question about a use case.
Right now I have a handful of sources going into my Sansui AU-5500 integrated. Turntable into the phono input through a SUT, streamer, tuner, and CD player on the other inputs. I have a MiniDSP Flex in the pre-out/main-in loop for DSP. I very much love this setup but I'm wondering if it could make sense to stick a Waxwing between the pre-out and the MiniDSP Flex at -0db volume, 0db gain, and "Line In" EQ instead of "Phono", while running the Magic function.
Basically all the line output from the Sansui would be processed through the Waxwing's Magic function with no additional signal processing. In theory if this works it should still be able to remove pops and clicks without altering any of the rest of the content no matter the source. I also wonder if it could help with needle drops like all the RidingEasy Brown Acid Trip LP's that sometimes have obvious quality issues.
