Subwoofer integration without external DSP
tomita
I'm planning adding a subwoofer to my system, but I don't want to use external DSP. Are there any guides I should follow in order to phase (/time) align the subwoofer to the mains solely by positioning and through the sub's own dsp settings (crossover, phase, etc.)?
Can it be done?
Thank you
If the sub has DSP, what is the problem using that? Of course without knowing a lot more about its capabilities, maybe it's not good enough. Tough to say.
You will get a better result if you can highpass your speakers. So ideally you should look into an external DSP solution. Phase/timing isn't necessarily a problem, true time aligning is impossible as the phase will vary with frequency.
You will have less issues if both subwoofer and speakers are sealed (not bass reflex).
No problem at all. I said I'm not going to use an external DSP. The subwoofer I'm considering is a SVS one, if that helps.
I know, but I don't want to go down that route. I want to make as much of a good integration as the interanl DSP of the subwoofer permits. The subwoofer will be sealed; the speakers, however, are ported – Kef R3.
That's a start. Got a link to a datasheet?
Thanks. Their idea of a datasheet is a glossy sales cut-sheet, unfortunately. Unless I missed some serious technical description of the DSP.
SVS App Specs:​
  • Powerful Bluetooth-controlled subwoofer DSP app works with iOS, Android, and Amazon operating systems
  • Provides easy and convenient way to adjust crossover frequencies, parametric EQ, polarity, room gain and all other bass-management functions
  • Three convenient custom presets allow for perfect tuning in any room or system, from your favorite seat
  • Bidirectional-feedback shows adjustments in real time on both app and subwoofer rear panel interface
If you don't want to high-pass the mains, you should match the low-pass of the subwoofer to the natural roll-off of the mains as well as possible. then you apply delay on a trial-and-error basis until you have the most SPL at the crossover. your sub will be probably a cycle too late though (360-degree shift), but most people won't hear that.
So far we're not sure the SVS app does delay.
the "phase" setting is probably delay, since there is polarity also
switch polarity first. leave polarity whatever gets most SPL before messing with the phase setting. if the polarity inversion gets you more SPL you will need less delay to match
I mean, what else would it be? an all-pass? I think these are generally delay when they are not simple polarity inversions
I'll take your word for it. This consumer grade stuff drives me crazy.
SVS App Specs:​
Are you looking for something specific? Maybe I can help. I tried to do my homework and I know a thing or two about their app's capabilities.
