Even stranger is when you really think the perfect measuring gear really sounds the same.
They do, with certain reservations. And it's these reservations that folks like you want to ignore and pretend we don't take into account.
Things like how an amp behaves as it nears clipping or becomes unhappy with certain details of the input or output impedance, etc. There are always certain details that can unset the sound of any particular component and these things are revealed when properly measured.
I'm sorry my friend, but there is
NO magic-dust in todays electronic reproduction chain that you can hear with your "24k golden-ears and incredibly resolving equipment" that can't and isn't measured.
Let me repeat:
'Good measuring" (and there's a subject to be explored) DAC's SHOULD sound the same. Good-measuring amps SHOULD sound the same. When compared fairly.
Exactly!
A big 10-4 there good buddy.
More expensive gear is typically better.
Better what?
Better looking, it damn well should be and usually is.
Better built, as in parts quality , again it damn well should be and usually is.
Better sounding, as in more accurate, transparent, better measuring? Oh hell no and quite often the reverse is very true.
The best examples would be things like tube gear and SET amps which normally measure full of distortion, who's output doesn't come close to resembling a straight wire with gain. They're just big tone controls and euphoric distortion creators.
