Dropbox, Google drive, one drive, or similar.I'll hopefully have some time before the end of the day.
What's the best way to post files?
wetransferI'll hopefully have some time before the end of the day.
Good quality 1/4 watt 1%/metal film resistors are less than $1.00 for 10 or less than $.25 if bought individually.
I decided to just go nuts and splurge. I just ordered:
Dale Brand CMF60 MIL-SPEC 1/2W Resistors, 1% Value: 8.25K (2) @ $0.45 = $0.90
Dale Brand CMF60 MIL-SPEC 1/2W Resistors, 1% Value: 12.1K (2) @ $0.45 = $0.90
Dale Brand CMF60 MIL-SPEC 1/2W Resistors, 1% Value: 56.2K (2) @ $0.45 = $0.90
Dale Brand CMF60 MIL-SPEC 1/2W Resistors, 1% Value: 150K (2) @ $0.45 = $0.90
Total: $3.60
Perhaps a little indulgent and audiophoolish of me, but hey #YOLO.
Yes, and that is where it still is with the Original d'Atelier, which is the same.
I sort of assumed that Ortofon's transformer was an appropriate match for their low output MCs into a standard MM input.
I use custom Cinemag SUTs with a tube preamp (Hovland Hp100). They also have excellent harmonic distortion and frequency response, but without the addition of a MU metal shield they were virtually unlistenable to- almost as bad as the Schiit Mani- and even with that they can't match an active preamp with a SMPS for hum rejection.You absolutely want a mu-metal can with as much shielding as possible.
Several have mentioned Cinemag. I'm using a DIY SUT I built in 2006 employing a pair of Cinemag CMQEE-3440A. This gives me some additional gain over the ~60dB or so my preamp MC stage provides. They work fantastic with my Denon DL-304 (0.19mV @ 1.2g) & Denon DL-103D (0.28mV @ 1.5g) low output moving coil cartridges in Orsonic AV-1 anti-vibration and Sumiko HS12 headshells. These with my George Merrill modified The AR Turntable with Sumiko Premier MMT tonearm, VTA-16 base, and Premier PIB-1 phono interface box.
The DIY SUT is shown in the right rear of this picture:
The transformer primaries are wired up to utilize the 37.5 and 150 Ohm taps. The output is fed to my preamplifier's phone stage. You can see the tiny ground wire to the left of the red RCA plug. It is tied to the preamp ground.
If you do a search you'll find lots of DIY examples on line going back to 2006 when I did mine.
It looks like you chose to forego the Zobel network, if I'm reading correctly.
If so, what are your thoughts about those who advocate using a Zobel to reduce transformer ringing vs just using resistors to do it?
I have a pair of these in my parts bin:
I will keep using my Technics SL10 MC stage and forget SUT. I am pretty well past DIY now, preferring plug-and-play.
Well, I have the parts to socket them on a die-cast jiffy box with RCA connectors and put them up on Ebay for a value-added hit. Hmmm.
Sorry. Three years later, I’m reviewing to refresh my memory, and I’m just now seeing this because I’m redoing my system, and would like to get it right this time. I didn’t start out at the top like you did, with Devialet. Don’t know why I missed the post originally.Did you add any load resistors to your Lundahl / K&K kit?
Any news regarding this? The world awaits!Sigh. It's looking like I'm going to have to put together an article on care and feeding of MC stepups.
Most of my audio projects are on temporary hold at the moment; dealing with some family issues which are keeping me away from my lab. But soon. In the meantime, there's still some good introductory info in my His Master's Noise article at diyAudio (I'm assuming it's still there).Any news regarding this? The world awaits!
Hope there's no serious health issues for you and your's SIYMost of my audio projects are on temporary hold at the moment; dealing with some family issues which are keeping me away from my lab.
