watchnerd
Below are two vinyl rips for listening comparison / digital file analysis. I'd love to get the feedback and insights of the collected community.
Source: Michell Gyro SE turntable / Jelco SA-750D tonearm / AT33EV cartridge
Medium: Side A of the Analogue Productions 45 RPM remastering of Getz / Gilberto
ADC Process: 24 bit / 96khz Devialet Expert 400 built-in ADC, RIAA via built in DSP (1976 EQ curve), USB out to Macbook, captured via Audacity and exported to FLAC. No other processing, normalization, or level matching.
WARNING: The files are 24bit / 96khz FLACs, unzipped, so about 190 MB each
Scenario 1, with SUT:
K&K Audio / Lundahl LL1931 SUT, set to 1:16 ratio / 24 dB gain
Loading: 183 ohms reflected (calculated, not measured), no additional resistors added
Input: Devialet set to MM mode, 4.7mv max input
File: https://drive.google.com/file/d/15Kgr17kfVf4Kg0ht0zWkig_XCL38VLAC/view?usp=sharing
Scenario 2, no SUT:
Straight into Devialet
Loading: 200 ohms (set per Devialet configuration UI, default for AT33EV preconfig)
Input: Devialet set to MC mode, 0.3mv max input
https://drive.google.com/file/d/1e0g-W4E1wlLz0xhbCZ-AK4-cYfC1OiKR/view?usp=sharing
The original rationale for getting a SUT was to reduce hiss / improve SNR of the phono stage. But I'm curious if others subjectively perceive or analytically deduce anything else going on.
Any comments or insights welcome!
Scenario 2, no SUT:
