You always decouple a speaker no matter the design. If you want to transfer the harmonics into or out of a piece of equipment you are on a lost journey.
You want the equipment to dissipate any vibration quickly or within your target by design. When any cabinet is coupled to ANY type of floor you can count
on smear. Even a concrete floor with anchored friction pears on 4 foot centers and a 5.5" slab will transfer vibration. The material under slabs subsides.
They normally get dryer and dryer under the slab. Very few homes on slabs or any slab has friction pears. Tilt ups are an exception.
The reality of it is, spend your money on good pods and enjoy the sound a whole lot more. They not only work for SQ they are a great step in quieting
down your hole domicile for you and others. It would be a shame to ONLY enjoy 80% of a great speaker when you could enjoy closer to 100%.
I'm not saying those numbers are accurate, but the difference in a treated room with no correction and decoupling speakers makes tuning your
speakers to your space a lot more achievable mechanically. Everything works better.
If you are a TT person you are one up again. I have seen ONE TT out of 100s that worked better on points. It was a direct drive too. So in 99% of the
turntable I've seen is easier to set up with pods vs points unless the points resting on pods. LOL
I've used a lot of different methods over the years. The least expensive and the best overall is air ride. A base that will hold an innertube is a wonderful
thing. Then "PODS", "Springs" and "sorbothane". I've tried sand pits, tennis balls, silicone gel packs, hanging in spring hangers, Setting on cantilever springs
Air and springs. 1 ton speakers EACH. Sand filled speakers, Concrete cabinets.
DECOUPLE everything and quit arguing. Subs are the worst for smearing mains... I quit using ANY bass in my main cabinets. That was a wakeup call too.
Different story but even with 400 + lb speakers and the narrowest front baffle I could buy, distortion from the bass section, FLOOR transfer and standing wave
bass frequencies all contributed to something you could definitely measure and hear. I didn't even bother measuring I knew what was going on from my
experience with IRS Betas for 13-15 years.
Speakers on the floor or spikes are just bad. So are open bottom speakers. IF a speaker has an open bottom and a driver, Put it in a slot.
The old REL are bad the new REL are good. Simple. The old ones can be fixed for 20 dollars. ADD a butt plate (slot) and mount the plate on springs or pods.
Have you EVER seen a stationary powerplant on SPIKES? They would last about 2 days before driving the spikes through the concrete slab. LOL All I have seen
in the last 40 years are on very special isolators that have bellows. Without front, rear and block dampeners they would crumble.
Points don't do the Cha Cha Cha much less the Lambada. More like a pogo sticks without the pogo. I think points on pods might work.
I still like innertubes and about 5 psi..
The idea of harmful harmonics is as old as knowing crappy cables = crappy sound or the engine won't start. Routing cables is as important as vibration control.
It cost little time and pays huge dividends. I don't bother listening to plug and drop systems anymore. A waste of my time and my ears.
I like your speakers though. Treat them and yourself to a good selection of cables, amps and pods. It doesn't cost a lot of money to do a great job either.
I'm just taking for granted you have room treatment in place. In any case enjoy placing those heavy mothers. LOL
Time to feed my chickens.
Regards
