nygafre
- Joined
- Aug 25, 2022
- Messages
- 148
- Likes
- 142
This morning I digged out my UMIK-1 to perform some measurements of my KEF R3 metas as I suspected their positioning were suboptimal.
I use my speakers in my living room both for movies and music. The speakers are placed on each side of the TV, on an 1.8 meters wide stand pretty close to the wall (conforming to estethics rather than rules of proper placement). This is my first proper attempt to measure with REW, so bear with me if I have missed something basic.
Original position:
The red curve shows the measurement from the speakers original placement. Here, the speakers are 1.6 meters apart, measured from top centre of each speaker. My listening-/measuring position is 2.4 meters away from the front of the speakers. Distance to back wall from back of speakers is (only) 150mm. I know KEF recommends a minimum of 225mm from the back wall.
Improved position:
The green curve shows the improved response. To improve the positioning, I put the speakers on nightstands on the side of the TV-stand, which increased the width to 2.25 meters centre to centre. I then continued by pulling the speakers out in steps of about 5-7 cm, and performed a measurement for each step. As I could see the response improving by each step, I continued until I reached what I found was close to optimal placement. The back of the speakers were now 340mm from the back wall.
Notes:
From the first (red) measurement, I was surprised to see the big valley in bass around 30-60Hz. The new position seemed to improve that, but then introduced smaller dips around e.g. 75Hz and 105-ish Hz. I have used 1/6th octave smoothing (don't know what is most commonly used). Without smoothing the dips were quite deep.
Both the red and green measurements were performed with the halfbungs in the port. I also did a measurement removing the bungs, which is shown by the purple curve in the following photo.
I found removing the bungs resulted in more bass, but after listening I think I prefer the response with the halfbungs in (green line). Things seemed a bit calmer that way.
My question would be how this looks in the more experienced eyes of the forum members here? I am already happy with the sound, but is there any obvious improvements I can do/explore? I currently don't own a sub, and as I have a neighbour on the other side of the wall I would be hesitant to introduce more bass. It would be interesting if I can improve things further, so any suggestions are welcomed.
Regards nygafre
Original position:
Improved position:
Notes:
Regards nygafre
