- Joined
- May 8, 2022
- Messages
- 714
- Likes
- 1,044
Oh man, ya beat me to it!The SU-1 does not have a headphone amp. It is only line-level out.
I stand corrected, thank you. I never have used the power button since I first powered up, it always lights up as soon as I plug in power, and these old eyes ain't what they used to be.View attachment 327231
Hm. Mine has a power (slash source) switch, and it DOESN'T turn on automatically... (powered via usb).
AKM's 4493S automatically switches to DSD direct mode when in DAC mode without volume control.Hello everyone, do we have any info if the dac has DSD Direct configuration built in? There is no volume control, so I hope that DSD direct configuration set.
Thanks for your comment. I also thought like this, but on the contrary maybe they disable DSD direct mode because of the low price. Because I had a look at the AK4493S datasheet and they mentioned that DSDD mode is enabled on register settings by the developer.AKM's 4493S automatically switches to DSD direct mode when in DAC mode without volume control.
The SU-1 is operating in DAC mode, so I think it is operating in DSD direct mode.
AKM's DAC chip has a DSD direct mode. DSD Direct is enabled by setting the volume to fixed DAC mode, but SMSL has not commented on this feature at all.Thanks for your comment. I also thought like this, but on the contrary maybe they disable DSD direct mode because of the low price. Because I had a look at the AK4493S datasheet and they mentioned that DSDD mode is enabled on register settings by the developer.
Normally, they mention this feature on the product pages if the DAC has this feature. Anyway, I asked this to their support, hope they will answer.
Support team answered to me and unfortunately DSD Direct mode is not enabled. And there is no option or config to perform this by ourselves.AKM's DAC chip has a DSD direct mode. DSD Direct is enabled by setting the volume to fixed DAC mode, but SMSL has not commented on this feature at all.
I hope they answer your question.
This is a completely disappointing answer. SMSL does not understand the merits of AK4493S at all.Support team answered to me and unfortunately DSD Direct mode is not enabled. And there is no option or config to perform this by ourselves.
I sent a follow up email and asked if they can prepare seperate firmware for the people who want DSD direct. And their response:This is a completely disappointing answer. SMSL does not understand the merits of AK4493S at all.
Interesting.I've just received mine - £67 or so on Amazon UK over the weekend, so twenty quid off the usual price. Got to say I'm enchanted by it, as it does seem slightly clearer than the admittedly safe-sounding CD player I compared it with (reverb and 'echo' is slightly less smudged to me) and 'hearing into' the mix is a doddle.
I'm not suggesting at all that it's the best thing since sliced bread and for the main rig, a Schiit would look better (can't get the cheaper Schiit dacs here currently anyway).
As it is for the second rig I'm using it in, it comes on to the previously selected input as soon as it's switched on and it's light enough that I can use 25cm interconnects and allow it to hang down the back of the unit the gear is on as it'll usually be set to take input from the PC SPDIF output, currently via optical, or a USB3 - USB-C cable if I can find a nice one around 3m long that doesn't suffer due to length?
No idea guv'nor, but it allows me to hear slightly better into the mixes on the rig compared to said rigs CD player analogue outs which in fairness were hardly reference standard, it cost me very little, it came nicely packaged and put together and I can hide it down the back as I don't need fancy-foo displays and so on.Interesting.
Well, does it sound better than a Linn DS or a Ikemi or Rega dac R ? Write what you think.
