tvrgeek
So the suggestion is you need a driver for higher bit depth and sample rates. Not my problem. I guess everyone makes a turd occasionally and I got theirs. Of course subjective " sounds great" is not the same as measuring the distortion and artifacts on the bench.
We were not talking a small difference. We are talking about an order of magnitude or more and spikes that should not be there at all and were not on the unit that was reviewed.
FWIW, I run my Muse on a linear supply, but it had a phones output which requires considerably more power. Todays project is actually putting the monster 2A wall wart into a diecast box with a power switch and fuse. A lot less "klunky" and easier to plug into my power strip/line filter that I am converting to USB controlled so when my PC comes on, so does the entire system. But no parasitic loads when off.
Again, if this unit required different drivers and requires an external power supply to meet spec, then it is still their fault for not saying so! No excuses for that. My Scarlett 2i2 came with a CD and INSTRUCTIONS. My MUSE does not require any.
