Name one consumer product from each of those brands please.The list would be long, butt small compagnies like Intel and Qualcomm for a start
Just pointing out that USA is, by a good margin the largest semiconductors components manufacturer in the world.
If they're using relays / FETs for doing the actual switching, then it's absolutely no problem.
CE can be self certified. It’s not a quality seal of approval unlike the FTC seal. It simply defines the entity to be legally responsible for the item.i wonder how many products with CE stickers were actually certified so far (not to bash China specifically, but you know what i mean...) ...
CE mark is a notice for the EU consumer. If you import for personal use you are exempt. You can’t re-sell it in a EU country.I have imported a Flux Labs FA-12S, which doesn't have any CE markings on it, and it went fine.
Thank you, and your company for allowing you interact with your customers. We are experiencing a new era in consumer audio electronics where designers talk direct to users.Thank you very much for the review of amirm.
SA-1 uses op amps from TI and the transistors from ON Semiconductor.
The 4 code switches at the bottom are from ALPS.
We test every ALPS potentiometer to meet our requirements.
Did I say they where doing consumer products?Name one consumer product from each of those brands please.
I second that.Thank you, and your company for allowing you interact with your customers. We are experiencing a new era in consumer audio electronics where designers talk direct to users.
Dude, read slide 6 and 10 of the document you just sent me...Do you have a reference for that? This US Industry source disagrees with you.
Sure, but what substantial consumer electronics manufacturing is going on there?
Please be polite. I’m not your dude, nor American.Dude, read slide 6 and 10 of the document you just sent me...
Sorry you got lost in the Plot there, go back to the discussion, I first commented on a statement that the US don't produce electronic parts, the contributor then, like you, tried to twist my words and make it about consumer electronic, I had to repeat that I was NOT talking about consumer electronics, sounds like I have to repeat it again... USA is not the largest manufacturer of consumer Electronic products, never tought that, never stated that, I don't know, if you read trough it's pretty clear what I sayYou commented to this post, where the object was consumer electronics.
Sorry for the familiarity, Yes there are others, but USA is the most important, 45% of the Global market to be precise. I don't understand, I'm sure you did a bit of statistic, go to these charts, one by one, and tell me which country is the largest producer of chips.Please be polite. I’m not your dude, nor American.
Page 5 title says: THE VAST MAJORITY OF SEMICONDUCTOR MANUFACTURING DONE IN THE UNITED STATES IS DONE BY U.S. FIRMS.
The chart is not about US manufacturer’s market share in the world. It’s what percentage the US companies produce at home. Believe it or not there are other manufacturers that are not American…
Then I apologise.Sorry you got lost in the Plot there, go back to the discussion, I first commented on a statement that the US don't produce electronic parts, the contributor then, like you, tried to twist my words and make it about consumer electronic, I had to repeat that I was NOT talking about consumer electronics, sounds like I have to repeat it again... USA is not the largest manufacturer of consumer Electronic products, never tought that, never stated that, I don't know, if you read trough it's pretty clear what I say
There’s nothing to understand. I was simply correcting you that USA is no longer by any margin the largest semiconductor manufacturers as you said in your post.Sorry for the familiarity, Yes there are others, but USA is the most important, 45% of the Global market to be precise. I don't understand, I'm sure you did a bit of statistic, go to these charts, one by one, and tell me which country is the largest producer of chips.
Can you explain why you think so? Why would it matter to switch a DC current instead of audio signal that affect switch detoriation?
Who is the largest semi-conductor manufacturer in the world?There’s nothing to understand. I was simply correcting you that USA is no longer by any margin the largest semiconductor manufacturers as you said in your post.
About being important; you may have read that US has recently lost the IC miniaturisation crown to a Taiwanese foundry, or Intel no longer the leader in CPUs.
I don’t know.Who is the largest semi-conductor manufacturer in the world?
Understood. Thank you.Minor contact oxidation is much less of a concern when switching 5V DC (or higher) as opposed to 100 mV audio signals. That's not to say it can't still cause an issue (it can), but it's much less common. When the switch contacts in the audio path get oxidized, you end up with intermittent connections, gross channel imbalances, extremely high distortion, etc.
