Sensitivity of opamps to air coupled EM fields, especially of the LM4562/LME497X0 family
JimB
California
Supposedly, the trick to getting the 4562 to work properly was to have a small inductor right at the input pin. I can't personally attest to that, but it's plausible and something I've seen with certain high transconductance discrete parts.
Any references to this you could send my way? :)
March Audio
Albany Western Australia
Alan @March Audio , these are time records that belong to the plots you did not like. It was the original unshielded universal PCB, as already described in post #1. The double-sided PCB with groundplane was produced just after these measurements and it significantly reduced the spikes, though not removed completely in case of LM4562. However, nothing can neglect the fact that different opamps behaved very differently in the same setup and that sensitivity of LM4562 to EM field was and is highest.
All plots for 86dB noise gain and -1 signal gain, input shorted.
Alan, may I ask you not to make cherry picking, not to pick up my measurements from the context of the post??
Universal unshielded PCB
LM4562 universal PCB
NE5532 universal PCB
TL072 universal PCB
Double-sided test PCB with ground plane
LM4562 double-sided test PCB with ground plane. The level of spikes is still high enough to be easily detected by spectral analysis.
LM4562 double-sided PCB, output amplified 30x and filtered by 20kHz 2RC LPF. Measured by oscilloscope only. USB not connected, PC is OFF.
Pavel, sorry but as mine and @SIY information has demonstrated this is an avoidable issue. It's all down to appropriate design, which will vary from component to component.
All of your plots show very high levels of mains pick up that should not be experienced, and are not experienced in normal audio designs with those various op amps. I highlighted the 5532 simply because we know that thousands of audio designers have decades of experience of that part without any issue.
As such it should have been obvious to you that investigation and review of your test methods was required as there is clearly something wrong. You have created pathological conditions which are not relevant to the real world. As such your info is misleading and unhelpful.
miero
KSTR
Berlin, Germany
Working around a design flaw is not the point here. The point is that this chip has this design shortcoming that actually does appear in real-world, non-pathological applications (compared to other, comparable opamps) and the sad part is that the problem is undocumented by the maker.
solderdude
The Neitherlands
The op-amp rolling crowd may get into trouble when rolling it in a circuit with a non suited PCB design/decoupling.
In all honesty I have been using the LM4562 a lot and never heard anything nasty but then again I do not 'measure' as deep and usually steel metal enclosures mostly. Maybe I've been lucky or didn't catch it yet.
March Audio
Well I think we need to perform more representative testing to characterise this to see how much of a real world problem it actually is. Different op amps have different characteristics that need to be appropriately designed for. Many op amps can have problems with EM/RF. What SIY said about this and the issues of op amp rolling is absolutely correct.
KSTR
Berlin, Germany
Agreed, but for this the characteristics have to be known and anything "non-typical" should be stated in the datasheet. Good example is the AD797 with its need of 100Ohms//22pF in the feedback, and preferably 100Ohm on the non-inverting input as well, for unity gain stability.
Also full ack on the imbecility of "op-amp rolling".
March Audio
There are probaby a lot of "real world" implementation issues that are not covered in data sheets.
KSTR
Berlin, Germany
Depends, I'd say. Some makers care more than others. Let's take the venerable 5532, the only competent datasheet that is available is the one for the NJM5532, with lot's of hints how to avoid pitfalls.
Now the 4562/49720 spec sheet is bloated with useless distortion graphs but some really important stuff is missing.
Circuit designer's time and effort is a premium and some companies provide extensive information even for most simple and cheapest consumer parts, some don't.
JensH
I just discovered this discussion due to a reference from another forum.
I can confirm that the LME49720 (family) is very sensitive to EMI. I have seen that on several occasions. Especially with unshielded test boards.
I think it would be beneficial to look at the sources of the EMI. This can help explain why some people experince the EMI problems and others don't, or at least to a lesser degree.
The 100 Hz noise clearly comes from a DECT system (I have worked with DECT development for almost 30 years, so I have seen this a lot!).
The 10 Hz is most likely from a Wi-Fi router.
In the first measurement in post #39 both can be seen. The DECT interference with intervals of exactly 10 ms and the Wi-Fi intereference with an interval just over 100 ms.
A quick test you could do: If you hook off the DECT phone and hold the handset close to your work bench, you will probably get a 200 Hz signal instead of the 100 Hz you have now. The peak level from the handset will generally be different from the peak level from the base station, due to the difference in distance etc.
The LME49720 can show good performance, but to avoid problems shielding is definitely recommended. A good PCB layout will help, but it cannot solve the problem in all cases.
I would recommend that you move the DECT base station and Wi-Fi router away from your test area. I used to have my DECT base station in the same room as my test setup, but I have moved it to a different room in the house.
Be aware that even when no phone connection is active the DECT base station will normally transmit a short slot every 10 ms. And, in Europe, it will normally transmit at a power level of 250 mW (in the US it is only 100 mW).
I have used a couple of LME49720's in the RTX6001 Audio Analyzer that I designed. With the lid removed I see some noise issues from nearby DECT equipment (we have a lot of that at work). But with the lid in place the noise disappears.
pma
pma
Prague
Thank you for your input, @JensH . As always personal experience and results are needed to make an opinion, armchair design approach is of little value.
I would like to add that I want for my circuits to work my designs under real world conditions flawlessly. So I will not create special conditions like moving modem away. If OPA2134 works flawlessly and LME49720 has big issues, then the latter part will never take place in my designs.
Arpiben
Now you may consider looking at 1.9 GHz interferers around your lab. ;)
Nevertheless specific locations will need much more care in terms of electronic shielding, i.e: Zizkov TV broadcast tower Prague.
Thanks.
Reactions: pma
pma
pma
Prague
Thanks.
Yeah, you are right, that's why it is important to me to select immune parts and not to bother with sensitive parts. Once again, no problems with any of the JFET opamps, no problems with AD797, ADA4898 and no problems with LT1028. Some issues with NE5532 and OPA211. For the reason that AD797 is much better part in audio band than LME49710, I stick with using AD797 if I need a low noise bipolar opamp.
More on opamps in audio band by Samuel Groner, the guy whose job I appreciate very highly.
http://www.nanovolt.ch/resources/ic_opamps/pdf/opamp_distortion.pdf
And that of @scott wurcer , former Analog Devices designer and the father of AD797. From the newer bipolar opamps, ADA4898 is approaching to AD797, but is not that good.
Arpiben
Fully agreeing with you regarding immune parts' selection. Thanks for your posts.
From my side nothing wrong about Zizkov, just an allusion since I worked in few of them in old analog TV broadcast days ( Kamzik,Bratislava / Collserola,Barcelona / Hillbrow,Johannesburg/...).
Rgds.
March Audio
This is not an armchair approach. This is precisely why I previously recommended to the DIY section not to use the Hypex Lm4562 eval board as it is not a "complete" design and will almost certainly have issues.
I showed you a hypex amp with an LM4562 buffer not showing a massive spread of 50 Hz harmonics (sat in a hostile RF environment and with a wifi router less than 1 m away).
NWav guys LM4562 plots were impeccable.
SIY showed you an impeccable LM4562 plot.
Nothing "armchair" about this. These are real world results.
There is nothing new about RF susceptibility in op amps. The solution is about appropriate design.
Your "personal experience and results" failed to get a 5532 working properly which should tell you there is something wrong with your test set-up.
ajawamnet
What in the DECT phone causes the 100Hz? I just did a quick test with my Panasonic KX-TG9541B phone...
https://shop.panasonic.com/cordless-corded-telephones/cordless-telephones/KX-TG9541B.html
Using my QA401. From what I've seen he's got an opamp (1612) and a diff amp (1632) -see these photos:
You'll see the OPA1612 appears to come right off of the atten relay. The 1632 appears to be the driver for the ADC. I know the mfg is on this site - be interesting for him to clarify this.
Here's a crappy Youboob vid of the test setup. There's a set of open leads on the QA401 left input. I use both ATTEN and non-ATTEN (you can see the switching).
All I see is typical SMPS and 60 cycle noise.
This is with the lid open.
The large spike is the 1.9GHz DECT from the handset... The second spike to the right is the WiFi router upstairs from my bench - about 3 meters away thru a wood floor...
Near the end of the vid I touch the clip probe - you can see the typical rise in noise...
SIY
Alfred, NY
There's nothing wrong with Pavel's test setup. It's just what's being tested and what conclusions are drawn from it that may be the source of disagreement. Remember, the test circuit (which he was very explicit about) is not at all representative of anything that would be used in an audio gain stage. So the results are correct for that circuit, but are irrelevant to circuits used in engineered audio equipment.
ajawamnet
BTW - if anyone's interested in what was in that DECT spike on the siglent - here's a close up:
Just a typical freq hop... A technique invented by Hedy Lamarr and her piano-playing friend back in 1941... sort of based on how player pianos work... whihc is also the basis of term Mechanical Royalties in the music biz...
Patent : https://patents.google.com/patent/US2292387A/en
It was filed under her married last name...
The story behind Hedy Lamarr’s game-changing flash of genius
https://www.iam-media.com/patents/hedy-lamarr-genius
