I want to know as well, everyone seems to have contradicting opinions. I know it has less treble than IE600 but people find that particular one bright. As long as it's no brighter than HD600 I'm happyAre these very bright iems? I have moondrop Starfield. Can anyone share short comparison with these?
I dont own them so feel free not to trust me, but looking at frequency response graphs, I expect them to sound very different from each other in the first place.I want to know as well, everyone seems to have contradicting opinions. I know it has less treble than IE600 but people find that particular one bright. As long as it's no brighter than HD600 I'm happy
I’ve had a pair for a month or two. The main criticism I have is not Sennheiser specific. The cable always gets tangled up with itself, it’s a real pain, and they are fiddly to put on. As for the cable being microphonic, mine isn’t. I go for hour long walks with them and there is no cable noise. There is however little sound isolation. When a car drives past, the noise drowns out the podcast I am listening to, which is why I went back to my Bose QC25 when walking outdoors. The sound is decent, certainly fine for the price. They are somewhat bright, but I prefer that to an exaggerated bass which is popular these days. My Sennheiser HD600 has far superior sound, but that’s hardly a surprise.Anyone has IE200 delivered yet? Any opinons?
Preamp: -3dB
Filter 1: ON LSC Fc 70 Hz Gain 2 dB Q 0.7
Filter 2: ON PK Fc 200 Hz Gain -1 dB Q 0.7
Filter 3: ON PK Fc 1500 Hz Gain -2 dB Q 1.4
Filter 4: ON PK Fc 8500 Hz Gain -3 dB Q 2
Filter 5: ON HSC Fc 10000 Hz Gain -2 dB Q 0.7
As for the bass, have you tried the MOD of the hole on the nozzle which consists in plugging it?Here is the EQ settings I use for IE200 in the off chance someone is interested.
This is how the FR graph looks like after EQ.
Also attached is the same PEQ settings in RME format.
No I haven't. How do you do that?As for the bass, have you tried the MOD of the hole on the nozzle which consists in plugging it?
Now they sound perfect even with the original eartips.
Placed side by side it is difficult to understand the differences between IE600 and IE200...
Whatever malleable material you have on hand.No I haven't. How do you do that?
I thought pushing the tips all the way in already sealed the port, doesn't it? Nevertheless, I will try tomorrow with a minute amount of blue tag to see if that makes a difference.Whatever malleable material you have on hand.
I used a microscopic amount of rubber/glue...
The same effect can also be had with some eartips (not all), but you lose comfort.
In theory it should have been like this.I thought pushing the tips all the way in already sealed the port, doesn't it? Nevertheless, I will try tomorrow with a minute amount of blue tag to see if that makes a difference.
It's not really proprietary, it's standard MMCX but recessed. You can use most MMCX cables if you clip the red and transparent plastic bits off the cable, which is super easy, they are held on by just one little plastic bit and cut that it will fit. Apart from that, you can get recessed MMCX cables that work without modification, I have a $9 cable on mine. AKG N5005 uses the same system and cables sold for that will also work. It's a slight annoyance and cables that work without the clip mod are not as common, but by no means a deal breaker. Plenty of $10-20 cables even if don't want to cut a regular one. Stock cable is rubbish.Been looking at these, but some reviews have turned me away from them a bit.
Apparently the cable is extra microphonic, kinda garbage and uses a proprietary connection so your only other "supported" option is $99.
Preamp: -10.0 dB
Filter 1: ON LSC Fc 20 Hz Gain 4.0 dB Q 0.250
Filter 2: ON PK Fc 3700 Hz Gain -6.0 dB Q 1.000
Filter 3: ON PK Fc 6000 Hz Gain 5.0 dB Q 1.000
Filter 4: ON HSC Fc 12000 Hz Gain 5.0 dB Q 0.700
