Correct. But it has only 2 slots so u cannot adjust it individually, unless u switch to other brands' eartips. As for qualities, be careful with the MMCX.Thank you [COLOR=rgb(0, 0, 0)][B]ArthuRScarlet[/B][/COLOR].
Slot 1 is when the ear tip is in the lower position so the nozzle sits deeper in the ear canal and slot 2 is the shallow version correct? Does it mean that we can play around with the insertion depth and create our own custom tuning
I don't think I hear beyond 13K very well even at +6db I think so I am not super worried about the higher peakFrom the graph and what you are describing, tonality sounds ok. Any opinions about other qualities other than tonality?
I have re-tested my IE200 and his video is right, if Spinfit CP100s were used, the bass will follow the response of IE600 (just 1dB less). But im not sure whether its a "Feature" to compensate the -2dB 3khz or just a "Mistake".Frequency response when the hole is closed tightly by dunu tip. Compare also to IE600. I should have IE200 in few days.
Would you say they are worth the price considering cost of getting new tips & probably a new cable if it's as bad as people are saying? This set is VERY interesting to me because I have had the chance to use other Senny iems and they are the most comfortable I have ever used. However, adding the cost of tips & a cable bring the cost closer to $200.I have re-tested my IE200 and his video is right, if Spinfit CP100s were used, the bass will follow the response of IE600 (just 1dB less). But im not sure whether its a "Feature" to compensate the -2dB 3khz or just a "Mistake".
I consider it as a mainstream IEM with its unique advantages (apparently different from those chifi competitors) in $150 market. So if u like the sound signiture, it worths $200 or even 300 ( unmatched bass quality with 3rd party eartips, comfort & Egonomics), better than IE300, if u dont, it worths $80, as close as HEXA or Aria for its better "resolution & clarity" and Bass, but with annoying, much sharper highs.Would you say they are worth the price considering cost of getting new tips & probably a new cable if it's as bad as people are saying? This set is VERY interesting to me because I have had the chance to use other Senny iems and they are the most comfortable I have ever used. However, adding the cost of tips & a cable bring the cost closer to $200.
It’s currently at $120USD, is it worth it over chi-fi competitors at the same prices?I consider it as a mainstream IEM with its unique advantages (apparently different from those chifi competitors) in $150 market. So if u like the sound signiture, it worths $200 or even 300 ( unmatched bass quality with 3rd party eartips, comfort & Egonomics), better than IE300, if u dont, it worths $80, as close as HEXA or Aria for its better "resolution & clarity" and Bass, but with annoying, much sharper highs.
It depends on personal taste that i cant judge. It has advantages such as bass and wearing comfort, but also some weakness like treble peaks.It’s currently at $120USD, is it worth it over chi-fi competitors at the same prices?
They're $167AUD currently, probs under $150 by black Friday, I also I got my cables for $20 - they're so much better than the OGsBeen looking at these, but some reviews have turned me away from them a bit.
Apparently the cable is extra microphonic, kinda garbage and uses a proprietary connection so your only other "supported" option is $99.
There's been reports of channel imbalance due to the bassport not being closed properly by stock tips as well.
There are major props for its comfort and its tuning, but tbh the market is so competitive right now that Sennheiser needs to be upping their game in regards to cables and drop the gimmicks that hurt functionality. Not gonna blow $200 AUD so I can spend $100 more on cables and tips.
Using a proprietary cable connector sucks too. It's just aggressively anti-consumer and I don't want to support it.
I sincerely wish many brands upped their IEM game, also in terms of tuning. The likes of Moondrop and Truthear have disrupted the market and it should have sent ripples but, the rest of the world seems to be moving rather incrementally in responce. I'm struggling not to be a fanboy of Chinese brands right now.but tbh the market is so competitive right now that Sennheiser needs to be upping their game
What should they do? Make headphones that adhere to Harman? When there already are those to be had for lunch money?I sincerely wish many brands upped their IEM game, also in terms of tuning. The likes of Moondrop and Truthear have disrupted the market and it should have sent ripples but, the rest of the world seems to be moving rather incrementally in responce. I'm struggling not to be a fanboy of Chinese brands right now.
They could change it and it would be be their new "house sound", In fact the current lien-up is a tuning departure from the previous line up.Maybe they could put one of those out just to make a point, but businesswise I think they are better off having their own sound, even if it's "wrong".
