I currently don't have an SACD player or any SACDs, but I just ordered the Sony UBP-X800M2 Blu-Ray player. However, I can send it back unopened if I get negative feedback on it here.
Right now I have a miniDSP Flex with balanced analog inputs, for a phono amp / turntable, and the usual three digital inputs. I have a computer plugged into the USB port. I use Dirac Live for room correction. My recollection is that the miniDSP does the room correction internally using PCM at 48 kHZ.
The obvious approach is to output the SACD from the Sony UBP-X800M2 as PCM on SPDIF. But this sounds like I might be downconverting the SACD / DSD to CD quality. Would it be best to limit the Sony UBP-X800M2 output to 48 kHZ, to match how the miniDSP Flex operates internally?
Also, if I am exporting PCM on SPDIF from the UBP-X800M2, should I just play the CD layer on a hybrid SACD and skip the entire SACD / DSD thing?
Is there a better option to get closer to DSD / SACD quality? Either a better SACD player or a better way to configure the output / input relationship between the Sony UBP-X800M2 and the miniDSP Flex?
Personnaly, I wouldn't be bothered by the fact that a one-bit sigma-delta modulated bitstream (which DSD is) is decimated into PCM. It is a completely banal technical process, used for decades to produce PCM.
To my mind, what you should be concerned about is the following: would any sound from an SA-CD be put out by the Sony player through Toslink at all? Reason is that, unless Sony has changed its policy before releasing the UBP-X800M2, the content of SA-CD discs can normally not be put out through S/PDIF or Toslink for copy protection reasons. That means that, with your current hardware set-up, you would only be able to send through Toslink the content of the CD layer of hybrid CD/SA-CD discs, but not the content of the high density (HD) layer or of any non-hybrid SA-CD disc. So, buying an UBP-X800M2 in the hope that you will be able to play the HD layer of SA-CD discs could end in disappointment.
But that's not necessarily a reason to give up on the UBP-X800M2. This device is able to play not only SA-CDs (only through its HDMI output, though), but also CDs, Blue-Ray discs, DVDs and even DVD-As. Disc spinning devices that can play the latter type of disc have become extremely rare. Thus, you would be able to play whatever disc format you own or plan to buy.
If your goal is to play (or rip) discs, whatever type they are, not necessarily SA-CD, the Sony appears to be a perfectly valid choice.
