ClearHearing
- Joined
- Oct 25, 2023
- Messages
- 72
- Likes
- 13
I currently don't have an SACD player or any SACDs, but I just ordered the Sony UBP-X800M2 Blu-Ray player. However, I can send it back unopened if I get negative feedback on it here.
Right now I have a miniDSP Flex with balanced analog inputs, for a phono amp / turntable, and the usual three digital inputs. I have a computer plugged into the USB port. I use Dirac Live for room correction. My recollection is that the miniDSP does the room correction internally using PCM at 48 kHZ.
The obvious approach is to output the SACD from the Sony UBP-X800M2 as PCM on SPDIF. But this sounds like I might be downconverting the SACD / DSD to CD quality. Would it be best to limit the Sony UBP-X800M2 output to 48 kHZ, to match how the miniDSP Flex operates internally?
Also, if I am exporting PCM on SPDIF from the UBP-X800M2, should I just play the CD layer on a hybrid SACD and skip the entire SACD / DSD thing?
Is there a better option to get closer to DSD / SACD quality? Either a better SACD player or a better way to configure the output / input relationship between the Sony UBP-X800M2 and the miniDSP Flex?
