The A30a I ordered from HiFi express arrived and I immediately tested it, but found a serious defect.
When playing with USB/Cox/OPT/AUX input, speaker output suddenly stops after a certain period of time. If you turn the power on and off or switch the input, it will return to normal operation. However, the sound soon disappears again. If any one of the inputs is normal, it can be used, but in this state it cannot be used at all.
I've measured the time from the start of playback until the sound stops, but it doesn't seem to be particularly consistent.
Time until no sound comes out
USB 58, 56, 54, 60, 59, 60, 55, 57, 60, 64 (sec)
Cox 31, 30, 33, 32, 34, 34, 32, 30, 71, 32 (sec)
Opt 60, 49, 58, 59, 59, 59, 58, 80, 46, 89 (sec)
Aux 72, 61, 63, 66, 60, 59, 56, 64, 42, 39 (sec)
Other than this issue it works fine.
I was worried about the operation of the DAC function when purchasing, but there is no problem with the connection and playback operation.
We have confirmed that PCM44.1~768kHz/DSD64~DSD512 for USB input and PCM44.1~192kHz for OPT/Cox all work properly.
I've compared the sound quality with the AO200, A300, and A2a 2022, but I think the A30a wins in all respects. The difference in grade is big.
However, it is very disappointing that it is sold with such a problem while having excellent sound quality. I will of course report this to Sabaj. Hopefully it will be fixed with a firmware update soon.
