- Joined
- Jun 5, 2020
- Messages
- 4,815
- Likes
- 3,752
I disagree with the first part, "always", due to the potential for subwoofer localizability and a degradation in sound quality. 60-80 Hz is often the sweet spot but it depends on a lot of factors that are different in each system.I disagree, subwoofer should always be crossed over at 80Hz or above, and if you have bass capable speakers than you can certainly cross them lower. Having 4 sources of bass is better than 2 in the scheme of fighting nulls.
I get what you're trying to do with the second part - even if it's not part of any standard system I've seen and not even in the more advanced EQ systems I have seen, such as Dirac Bass Control. In theory more bass sources could be better, however these bass sources in this case are not equal in capability. Unless you are trying to address a specific issue and understand well the limitations of each piece of equipment, I would stick with the standard of low passing and high passing at the same frequency.
