RME Babyface Pro FS Portable Interface Review
MC_RME
TotalMix FX can do anything, stereo or mono channels. ASIO too. WDM is stereo pairs, so the software needs to support that free routing.
Sir Sanders Zingmore
Melbourne, Australia
Sorry to jump in on someone else’s question but can the 4 analog outs be used as a part of two way stereo crossover ( stereo to bass amp and stereo to mid/tweeter amp in my use case) ?
Music1969
Thanks.
And what about Linux (ALSA?)
Like latest Ubuntu 20.04.1 LTS ?
Mono channels or only stereo pairs?
MC_RME
Of course. But seems to be the wrong interface for such a task.
MC_RME
The phones outputs are unbalanced but super-low impedance, so will work. You have to gang all 4 output levels permanently in TM FX, or you can't control volume at the unit.
Music1969
Hi @MC_RME
On Linux (ALSA mixer, via latest Ubuntu Focal 20.04.1 LTS kernel), are the 4 analogue outputs mono?
Or two stereo pairs?
MC_RME
That's a question for Linux users...
Blumlein 88
I love your honesty.
While I might think it a bad thing that you as the expert on things RME can't answer the question about linux, I understand it. It is the problem with linux and things audio. Various distros probably act differently, and there isn't enough standardization for you to possibly answer the question. Plus linux is surely not the primary market for your devices. So you answered with simple humility and honesty. You'll have to ask linux users.
MC_RME
Indeed we have no offical support for Linux, so no one here tests our units on it.
msmucr
Prague, Czech Republic
Hi @MC_RME
I'm not sure if you're a bit familiar with operation of audio interfaces at Linux, but that really depends on used application and software setup.
The BF Pro itself has two operational modes - PC , or CC mode.
The first one uses proprietary communication protocol and requires RME drivers at supported OS - eg. Windows or macOS. All available hardware features are exposed via TotalMix control application. There you can control hardware mixing of playback and input audio channels, route them or apply hardware parametric EQ.
In the other CC mode (USB audio class compliant) you can use it with any suitable driver supporting this standard, for example at Linux. In this case, the interface appears as 12 in, 12 out audio device (4x analog, 8x ADAT). Some limited hardware functions are then accessible via encoder and buttons on the interface. Check BF Pro manual about details of CC mode.
So how you approach the 12 channel device in Linux is then completely up to you. In Linux there are multiple ways how you might access it and how exactly you implement the room correction, crossover etc.
You can for example create virtual stereo loopback ALSA device (snd_aloop module), which you will use as main stereo device for playback from normal applications. Then you might use looped output from this device as an input to some processing program like Ecasound or BruteFIR, where you apply the actual correction. The output from such program will be then sent to desired channels of actual ALSA hardware device.
However as I've mentioned, there might be many other ways - you might use some other audio subsystems like PulseAudio, JACK, you can employ some LADSPA plugins.. etc. It's bit open ended at Linux, there might be also other operational considerations and result really depends on how much time and efforts you're willing to spend there ;)
Also as MC mentioned previously, the top panel knob at BF Pro controls selected stereo pair. So you'd have hardware volume control just for one pair of audio outputs (like main XLR outs or phones). In PC operational mode with TotalMix software, there is an option to "gang" several output faders channels together, so you can effectively control all output channels simultaneously. But as I've mentioned, this mode won't be applicable when running at Linux and you'll have to use some different method for volume control of all four channels.
Michal
P.S.: I don't currently have nor use BF Pro at Linux. I've used it before at Windows and macOS - it's a great compact audio interface.
Music1969
I'm familiar with the manual and CC mode.
Many interfaces claim to be USB Class Audio 2 compliant but users have other experiences...
https://linuxmusicians.com/viewtopic.php?f=6&t=21163&sid=e9d758cd9280adfdff5d7f95831d2a64
So I was simply asking @MC_RME about Linux support - which he answered, it's not official supported.
I own an ADI-2 FS btw... but that still won't help me answer my question about 4 mono channels with the BabyFace Pro FS on Linux... A pair of stereo outputs isn't what I want.
somebodyelse
The patch that added support for the Babyface Pro FS adds a mixer interface for the class compliant mode. It was meant to go into the 5.8 kernel release - I haven't checked that it did. If I'm reading it right you get a full mix matrix, so a LOT of controls. I don't have one to check this, and can't say whether there are any compatibility isues.
As @msmucr says it's up to you, and to some extent the application you're using, how to use the available channels in linux. See the BruteFIR docs for how flexible it is in dealing with channels (including odd numbers of them), or this crossover example to see how the usage of each channel can be defined in its config. You could try it out with the surround output on many motherboards, or with a cheap card with surround oputputs, as these are just another block of 6 or 8 outputs to linux.
magchiel
Previously used (i.e. specifically bought to use) my Babyface Pro with Reaper and Mixbus through JACK under Linux without any diffulties (now using Windows for my DAW now due to VST compatibility).
Quickly hooked it up in CC mode on my (non DAW) Linux system and speaker-test -Dplug:hw:Pro71973963 -r192000 -FS32_LE -c4 succesfully produces pink noise on all the channels on my monitors and headphones (channels 0 and 1 are the XLR L/R out; channels 2 and 3 the headphone L/R out) so I can see no reason you can't map everything to 4 mono channels as indicated by @msmucr and @somebodyelse.
Running 5.9.11-arch2-1, amixer indeed lists the entire matrix.
Code:
$ amixer -Dhw:Pro71973963
Simple mixer control 'PCM-ADAT3-ADAT3',0
  Capabilities: pvolume pvolume-joined
  Playback channels: Mono
  Limits: Playback 0 - 65536
  Mono: Playback 0 [0%]
Simple mixer control 'PCM-ADAT3-ADAT4',0
Simple mixer control 'PCM-ADAT3-ADAT5',0
Simple mixer control 'PCM-ADAT3-ADAT6',0
Simple mixer control 'PCM-ADAT3-ADAT7',0
Simple mixer control 'PCM-ADAT3-ADAT8',0
Simple mixer control 'PCM-ADAT3-AN1',0
Simple mixer control 'PCM-ADAT3-AN2',0
Simple mixer control 'PCM-ADAT3-AS1',0
Simple mixer control 'PCM-ADAT3-AS2',0
Simple mixer control 'PCM-ADAT3-PH3',0
Simple mixer control 'PCM-ADAT3-PH4',0
Simple mixer control 'PCM-ADAT4-ADAT3',0
Simple mixer control 'PCM-ADAT4-ADAT4',0
Simple mixer control 'PCM-ADAT4-ADAT5',0
Simple mixer control 'PCM-ADAT4-ADAT6',0
Simple mixer control 'PCM-ADAT4-ADAT7',0
Simple mixer control 'PCM-ADAT4-ADAT8',0
Simple mixer control 'PCM-ADAT4-AN1',0
Simple mixer control 'PCM-ADAT4-AN2',0
Simple mixer control 'PCM-ADAT4-AS1',0
Simple mixer control 'PCM-ADAT4-AS2',0
Simple mixer control 'PCM-ADAT4-PH3',0
Simple mixer control 'PCM-ADAT4-PH4',0
Simple mixer control 'PCM-ADAT5-ADAT3',0
Simple mixer control 'PCM-ADAT5-ADAT4',0
Simple mixer control 'PCM-ADAT5-ADAT5',0
Simple mixer control 'PCM-ADAT5-ADAT6',0
Simple mixer control 'PCM-ADAT5-ADAT7',0
Simple mixer control 'PCM-ADAT5-ADAT8',0
Simple mixer control 'PCM-ADAT5-AN1',0
Simple mixer control 'PCM-ADAT5-AN2',0
Simple mixer control 'PCM-ADAT5-AS1',0
Simple mixer control 'PCM-ADAT5-AS2',0
Simple mixer control 'PCM-ADAT5-PH3',0
Simple mixer control 'PCM-ADAT5-PH4',0
Simple mixer control 'PCM-ADAT6-ADAT3',0
Simple mixer control 'PCM-ADAT6-ADAT4',0
Simple mixer control 'PCM-ADAT6-ADAT5',0
Simple mixer control 'PCM-ADAT6-ADAT6',0
Simple mixer control 'PCM-ADAT6-ADAT7',0
Simple mixer control 'PCM-ADAT6-ADAT8',0
Simple mixer control 'PCM-ADAT6-AN1',0
Simple mixer control 'PCM-ADAT6-AN2',0
Simple mixer control 'PCM-ADAT6-AS1',0
Simple mixer control 'PCM-ADAT6-AS2',0
Simple mixer control 'PCM-ADAT6-PH3',0
Simple mixer control 'PCM-ADAT6-PH4',0
Simple mixer control 'PCM-ADAT7-ADAT3',0
Simple mixer control 'PCM-ADAT7-ADAT4',0
Simple mixer control 'PCM-ADAT7-ADAT5',0
Simple mixer control 'PCM-ADAT7-ADAT6',0
Simple mixer control 'PCM-ADAT7-ADAT7',0
Simple mixer control 'PCM-ADAT7-ADAT8',0
Simple mixer control 'PCM-ADAT7-AN1',0
Simple mixer control 'PCM-ADAT7-AN2',0
Simple mixer control 'PCM-ADAT7-AS1',0
Simple mixer control 'PCM-ADAT7-AS2',0
Simple mixer control 'PCM-ADAT7-PH3',0
Simple mixer control 'PCM-ADAT7-PH4',0
Simple mixer control 'PCM-ADAT8-ADAT3',0
Simple mixer control 'PCM-ADAT8-ADAT4',0
Simple mixer control 'PCM-ADAT8-ADAT5',0
Simple mixer control 'PCM-ADAT8-ADAT6',0
Simple mixer control 'PCM-ADAT8-ADAT7',0
Simple mixer control 'PCM-ADAT8-ADAT8',0
Simple mixer control 'PCM-ADAT8-AN1',0
Simple mixer control 'PCM-ADAT8-AN2',0
Simple mixer control 'PCM-ADAT8-AS1',0
Simple mixer control 'PCM-ADAT8-AS2',0
Simple mixer control 'PCM-ADAT8-PH3',0
Simple mixer control 'PCM-ADAT8-PH4',0
Simple mixer control 'PCM-AN1-ADAT3',0
Simple mixer control 'PCM-AN1-ADAT4',0
Simple mixer control 'PCM-AN1-ADAT5',0
Simple mixer control 'PCM-AN1-ADAT6',0
Simple mixer control 'PCM-AN1-ADAT7',0
Simple mixer control 'PCM-AN1-ADAT8',0
Simple mixer control 'PCM-AN1-AN1',0
Simple mixer control 'PCM-AN1-AN2',0
Simple mixer control 'PCM-AN1-AS1',0
Simple mixer control 'PCM-AN1-AS2',0
Simple mixer control 'PCM-AN1-PH3',0
Simple mixer control 'PCM-AN1-PH4',0
Simple mixer control 'PCM-AN2-ADAT3',0
Simple mixer control 'PCM-AN2-ADAT4',0
Simple mixer control 'PCM-AN2-ADAT5',0
Simple mixer control 'PCM-AN2-ADAT6',0
Simple mixer control 'PCM-AN2-ADAT7',0
Simple mixer control 'PCM-AN2-ADAT8',0
Simple mixer control 'PCM-AN2-AN1',0
Simple mixer control 'PCM-AN2-AN2',0
Simple mixer control 'PCM-AN2-AS1',0
Simple mixer control 'PCM-AN2-AS2',0
Simple mixer control 'PCM-AN2-PH3',0
Simple mixer control 'PCM-AN2-PH4',0
Simple mixer control 'PCM-AS1-ADAT3',0
Simple mixer control 'PCM-AS1-ADAT4',0
Simple mixer control 'PCM-AS1-ADAT5',0
Simple mixer control 'PCM-AS1-ADAT6',0
Simple mixer control 'PCM-AS1-ADAT7',0
Simple mixer control 'PCM-AS1-ADAT8',0
Simple mixer control 'PCM-AS1-AN1',0
Simple mixer control 'PCM-AS1-AN2',0
Simple mixer control 'PCM-AS1-AS1',0
Simple mixer control 'PCM-AS1-AS2',0
Simple mixer control 'PCM-AS1-PH3',0
Simple mixer control 'PCM-AS1-PH4',0
Simple mixer control 'PCM-AS2-ADAT3',0
Simple mixer control 'PCM-AS2-ADAT4',0
Simple mixer control 'PCM-AS2-ADAT5',0
Simple mixer control 'PCM-AS2-ADAT6',0
Simple mixer control 'PCM-AS2-ADAT7',0
Simple mixer control 'PCM-AS2-ADAT8',0
Simple mixer control 'PCM-AS2-AN1',0
Simple mixer control 'PCM-AS2-AN2',0
Simple mixer control 'PCM-AS2-AS1',0
Simple mixer control 'PCM-AS2-AS2',0
Simple mixer control 'PCM-AS2-PH3',0
Simple mixer control 'PCM-AS2-PH4',0
Simple mixer control 'PCM-PH3-ADAT3',0
Simple mixer control 'PCM-PH3-ADAT4',0
Simple mixer control 'PCM-PH3-ADAT5',0
Simple mixer control 'PCM-PH3-ADAT6',0
Simple mixer control 'PCM-PH3-ADAT7',0
Simple mixer control 'PCM-PH3-ADAT8',0
Simple mixer control 'PCM-PH3-AN1',0
Simple mixer control 'PCM-PH3-AN2',0
Simple mixer control 'PCM-PH3-AS1',0
Simple mixer control 'PCM-PH3-AS2',0
Simple mixer control 'PCM-PH3-PH3',0
Simple mixer control 'PCM-PH3-PH4',0
Simple mixer control 'PCM-PH4-ADAT3',0
Simple mixer control 'PCM-PH4-ADAT4',0
Simple mixer control 'PCM-PH4-ADAT5',0
Simple mixer control 'PCM-PH4-ADAT6',0
Simple mixer control 'PCM-PH4-ADAT7',0
Simple mixer control 'PCM-PH4-ADAT8',0
Simple mixer control 'PCM-PH4-AN1',0
Simple mixer control 'PCM-PH4-AN2',0
Simple mixer control 'PCM-PH4-AS1',0
Simple mixer control 'PCM-PH4-AS2',0
Simple mixer control 'PCM-PH4-PH3',0
Simple mixer control 'PCM-PH4-PH4',0
Simple mixer control 'Line-ADAT3-ADAT3',0
Simple mixer control 'Line-ADAT3-ADAT4',0
Simple mixer control 'Line-ADAT3-ADAT5',0
Simple mixer control 'Line-ADAT3-ADAT6',0
Simple mixer control 'Line-ADAT3-ADAT7',0
Simple mixer control 'Line-ADAT3-ADAT8',0
Simple mixer control 'Line-ADAT3-AN1',0
Simple mixer control 'Line-ADAT3-AN2',0
Simple mixer control 'Line-ADAT3-AS1',0
Simple mixer control 'Line-ADAT3-AS2',0
Simple mixer control 'Line-ADAT3-PH3',0
Simple mixer control 'Line-ADAT3-PH4',0
Simple mixer control 'Line-ADAT4-ADAT3',0
Simple mixer control 'Line-ADAT4-ADAT4',0
Simple mixer control 'Line-ADAT4-ADAT5',0
Simple mixer control 'Line-ADAT4-ADAT6',0
Simple mixer control 'Line-ADAT4-ADAT7',0
Simple mixer control 'Line-ADAT4-ADAT8',0
Simple mixer control 'Line-ADAT4-AN1',0
Simple mixer control 'Line-ADAT4-AN2',0
Simple mixer control 'Line-ADAT4-AS1',0
Simple mixer control 'Line-ADAT4-AS2',0
Simple mixer control 'Line-ADAT4-PH3',0
Simple mixer control 'Line-ADAT4-PH4',0
Simple mixer control 'Line-ADAT5-ADAT3',0
Simple mixer control 'Line-ADAT5-ADAT4',0
Simple mixer control 'Line-ADAT5-ADAT5',0
Simple mixer control 'Line-ADAT5-ADAT6',0
Simple mixer control 'Line-ADAT5-ADAT7',0
Simple mixer control 'Line-ADAT5-ADAT8',0
Simple mixer control 'Line-ADAT5-AN1',0
Simple mixer control 'Line-ADAT5-AN2',0
Simple mixer control 'Line-ADAT5-AS1',0
Simple mixer control 'Line-ADAT5-AS2',0
Simple mixer control 'Line-ADAT5-PH3',0
Simple mixer control 'Line-ADAT5-PH4',0
Simple mixer control 'Line-ADAT6-ADAT3',0
Simple mixer control 'Line-ADAT6-ADAT4',0
Simple mixer control 'Line-ADAT6-ADAT5',0
Simple mixer control 'Line-ADAT6-ADAT6',0
Simple mixer control 'Line-ADAT6-ADAT7',0
Simple mixer control 'Line-ADAT6-ADAT8',0
Simple mixer control 'Line-ADAT6-AN1',0
Simple mixer control 'Line-ADAT6-AN2',0
Simple mixer control 'Line-ADAT6-AS1',0
Simple mixer control 'Line-ADAT6-AS2',0
Simple mixer control 'Line-ADAT6-PH3',0
Simple mixer control 'Line-ADAT6-PH4',0
Simple mixer control 'Line-ADAT7-ADAT3',0
Simple mixer control 'Line-ADAT7-ADAT4',0
Simple mixer control 'Line-ADAT7-ADAT5',0
Simple mixer control 'Line-ADAT7-ADAT6',0
Simple mixer control 'Line-ADAT7-ADAT7',0
Simple mixer control 'Line-ADAT7-ADAT8',0
Simple mixer control 'Line-ADAT7-AN1',0
Simple mixer control 'Line-ADAT7-AN2',0
Simple mixer control 'Line-ADAT7-AS1',0
Simple mixer control 'Line-ADAT7-AS2',0
Simple mixer control 'Line-ADAT7-PH3',0
Simple mixer control 'Line-ADAT7-PH4',0
Simple mixer control 'Line-ADAT8-ADAT3',0
Simple mixer control 'Line-ADAT8-ADAT4',0
Simple mixer control 'Line-ADAT8-ADAT5',0
Simple mixer control 'Line-ADAT8-ADAT6',0
Simple mixer control 'Line-ADAT8-ADAT7',0
Simple mixer control 'Line-ADAT8-ADAT8',0
Simple mixer control 'Line-ADAT8-AN1',0
Simple mixer control 'Line-ADAT8-AN2',0
Simple mixer control 'Line-ADAT8-AS1',0
Simple mixer control 'Line-ADAT8-AS2',0
Simple mixer control 'Line-ADAT8-PH3',0
Simple mixer control 'Line-ADAT8-PH4',0
Simple mixer control 'Line-AS1-ADAT3',0
Simple mixer control 'Line-AS1-ADAT4',0
Simple mixer control 'Line-AS1-ADAT5',0
Simple mixer control 'Line-AS1-ADAT6',0
Simple mixer control 'Line-AS1-ADAT7',0
Simple mixer control 'Line-AS1-ADAT8',0
Simple mixer control 'Line-AS1-AN1',0
Simple mixer control 'Line-AS1-AN2',0
Simple mixer control 'Line-AS1-AS1',0
Simple mixer control 'Line-AS1-AS2',0
Simple mixer control 'Line-AS1-PH3',0
Simple mixer control 'Line-AS1-PH4',0
Simple mixer control 'Line-AS2-ADAT3',0
Simple mixer control 'Line-AS2-ADAT4',0
Simple mixer control 'Line-AS2-ADAT5',0
Simple mixer control 'Line-AS2-ADAT6',0
Simple mixer control 'Line-AS2-ADAT7',0
Simple mixer control 'Line-AS2-ADAT8',0
Simple mixer control 'Line-AS2-AN1',0
Simple mixer control 'Line-AS2-AN2',0
Simple mixer control 'Line-AS2-AS1',0
Simple mixer control 'Line-AS2-AS2',0
Simple mixer control 'Line-AS2-PH3',0
Simple mixer control 'Line-AS2-PH4',0
Simple mixer control 'Line-IN3-ADAT3',0
Simple mixer control 'Line-IN3-ADAT4',0
Simple mixer control 'Line-IN3-ADAT5',0
Simple mixer control 'Line-IN3-ADAT6',0
Simple mixer control 'Line-IN3-ADAT7',0
Simple mixer control 'Line-IN3-ADAT8',0
Simple mixer control 'Line-IN3-AN1',0
Simple mixer control 'Line-IN3-AN2',0
Simple mixer control 'Line-IN3-AS1',0
Simple mixer control 'Line-IN3-AS2',0
Simple mixer control 'Line-IN3-PH3',0
Simple mixer control 'Line-IN3-PH4',0
Simple mixer control 'Line-IN4-ADAT3',0
Simple mixer control 'Line-IN4-ADAT4',0
Simple mixer control 'Line-IN4-ADAT5',0
Simple mixer control 'Line-IN4-ADAT6',0
Simple mixer control 'Line-IN4-ADAT7',0
Simple mixer control 'Line-IN4-ADAT8',0
Simple mixer control 'Line-IN4-AN1',0
Simple mixer control 'Line-IN4-AN2',0
Simple mixer control 'Line-IN4-AS1',0
Simple mixer control 'Line-IN4-AS2',0
Simple mixer control 'Line-IN4-PH3',0
Simple mixer control 'Line-IN4-PH4',0
Simple mixer control 'Line-IN3 Sens.',0
  Capabilities: enum
  Items: '-10dBV' '+4dBu'
  Item0: '-10dBV'
Simple mixer control 'Line-IN4 Sens.',0
  Capabilities: enum
  Item0: '-10dBV'
Simple mixer control 'Mic-AN1-ADAT3',0
Simple mixer control 'Mic-AN1-ADAT4',0
Simple mixer control 'Mic-AN1-ADAT5',0
Simple mixer control 'Mic-AN1-ADAT6',0
Simple mixer control 'Mic-AN1-ADAT7',0
Simple mixer control 'Mic-AN1-ADAT8',0
Simple mixer control 'Mic-AN1-AN1',0
Simple mixer control 'Mic-AN1-AN2',0
Simple mixer control 'Mic-AN1-AS1',0
Simple mixer control 'Mic-AN1-AS2',0
Simple mixer control 'Mic-AN1-PH3',0
Simple mixer control 'Mic-AN1-PH4',0
Simple mixer control 'Mic-AN2-ADAT3',0
Simple mixer control 'Mic-AN2-ADAT4',0
Simple mixer control 'Mic-AN2-ADAT5',0
Simple mixer control 'Mic-AN2-ADAT6',0
Simple mixer control 'Mic-AN2-ADAT7',0
Simple mixer control 'Mic-AN2-ADAT8',0
Simple mixer control 'Mic-AN2-AN1',0
Simple mixer control 'Mic-AN2-AN2',0
Simple mixer control 'Mic-AN2-AS1',0
Simple mixer control 'Mic-AN2-AS2',0
Simple mixer control 'Mic-AN2-PH3',0
Simple mixer control 'Mic-AN2-PH4',0
Simple mixer control 'Mic-AN1 48V',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [off]
Simple mixer control 'Mic-AN1 PAD',0
Simple mixer control 'Mic-AN2 48V',0
Simple mixer control 'Mic-AN2 PAD',0
Simple mixer control 'IEC958',0
Simple mixer control 'IEC958 Emphasis',0
Simple mixer control 'IEC958 Pro Mask',0
Simple mixer control 'Sample Clock Source',0
  Capabilities: enum
  Items: 'AutoSync' 'Internal'
  Item0: 'AutoSync'
somebodyelse
Thanks for the confirmation - it's every bit as monstrous as I thought! I don't know if anyone has done a GUI to make it a bit more usable than alsamixer would be.
L5730
East of England
I was very pleased that the ASIO driver package was just 10 kBytes
Hmm, I don't know what file this was, but the driver I downloaded was a 10.1MB zip file.
It's quite a nice feeling unit. Doesn't scoot around the desk, so those little rubber feet work, as does it's own weight. Buttons are tight and robust. The rotary encoder has little notches and no wobble or play.
It can be powered with the same DC (+ tip) PSU that one would use for guitar pedals, providing 9v. I've read at least 2 Amps, but the manual also says a lot less current is required from an external PSU.
There's plenty of headroom for Customshop Texas Special pickups.
I've still got a ground loop to the active speakers, but can solve it with a ground life on the balanced cables. There is no buzz, but a very faint digital hash. I purposefully listened for it, knowing I have a loop issue with other equipment.
I do wish it had locking connectors, even if just the output ones to the monitors. I know why they didn't put them on the inputs, snags and possibility to break on such a portable device, but still. Amphenol female connectors are staying put under their own friction however.
MC_RME
Standard (if there is one) for foot stompers is exactly the opposite: + is the outer connector, so that won't work. This scheme has been a not much logical choice from the beginning, as any unused PS connector on multi-connector cables need to be isolated to not short when touching ground (like a devices metal case).
L5730
East of England
^ Yeah, please everyone pay attention to the above.
I don't know what I was thinking, stomp boxes are usually centre negative, aren't they!? Doh!
We've a multi-volt PSU with different connectors which are reversible, and I've used it to power stomp boxes before. It powered the BFPfs fine, although I didn't max out current draw (phantom power, lights on full, etc..). I quadruple checked I had the polarity the right way around before plugging it in.
The Digicheck software is quite nice.
Latency is audibly non-existent (to me) on an AMD Ryzen 1700X/ASRock ThaiChi @ 128 samples 44.1kHz.
The MIDI port has an old Line6 POD 2.0 dangling off of it for extended patch editing. That still works and is good fun.
JBX1666
Thank you for the measurements @amirm. I have been very happy with the non FS model for the last four years. One issue I have is the plastic used in the XLR connectors and power supply jack, which seems to be fragile and brittle. I am not changing my setup often, but I have noticed wear (abrasion) on all sockets immediately. Maybe something to consider, especially since it is intended as a portable interface.
Is this still a problem with the new FS version?
Thanks.
CC @MC_RME
