$ amixer -Dhw:Pro71973963
Simple mixer control 'PCM-ADAT3-ADAT3',0
Capabilities: pvolume pvolume-joined
Playback channels: Mono
Limits: Playback 0 - 65536
Mono: Playback 0 [0%]
Simple mixer control 'PCM-ADAT3-ADAT4',0
Simple mixer control 'PCM-ADAT3-ADAT5',0
Simple mixer control 'PCM-ADAT3-ADAT6',0
Simple mixer control 'PCM-ADAT3-ADAT7',0
Simple mixer control 'PCM-ADAT3-ADAT8',0
Simple mixer control 'PCM-ADAT3-AN1',0
Simple mixer control 'PCM-ADAT3-AN2',0
Simple mixer control 'PCM-ADAT3-AS1',0
Simple mixer control 'PCM-ADAT3-AS2',0
Simple mixer control 'PCM-ADAT3-PH3',0
Simple mixer control 'PCM-ADAT3-PH4',0
Simple mixer control 'PCM-ADAT4-ADAT3',0
Simple mixer control 'PCM-ADAT4-ADAT4',0
Simple mixer control 'PCM-ADAT4-ADAT5',0
Simple mixer control 'PCM-ADAT4-ADAT6',0
Simple mixer control 'PCM-ADAT4-ADAT7',0
Simple mixer control 'PCM-ADAT4-ADAT8',0
Simple mixer control 'PCM-ADAT4-AN1',0
Simple mixer control 'PCM-ADAT4-AN2',0
Simple mixer control 'PCM-ADAT4-AS1',0
Simple mixer control 'PCM-ADAT4-AS2',0
Simple mixer control 'PCM-ADAT4-PH3',0
Simple mixer control 'PCM-ADAT4-PH4',0
Simple mixer control 'PCM-ADAT5-ADAT3',0
Simple mixer control 'PCM-ADAT5-ADAT4',0
Simple mixer control 'PCM-ADAT5-ADAT5',0
Simple mixer control 'PCM-ADAT5-ADAT6',0
Simple mixer control 'PCM-ADAT5-ADAT7',0
Simple mixer control 'PCM-ADAT5-ADAT8',0
Simple mixer control 'PCM-ADAT5-AN1',0
Simple mixer control 'PCM-ADAT5-AN2',0
Simple mixer control 'PCM-ADAT5-AS1',0
Simple mixer control 'PCM-ADAT5-AS2',0
Simple mixer control 'PCM-ADAT5-PH3',0
Simple mixer control 'PCM-ADAT5-PH4',0
Simple mixer control 'PCM-ADAT6-ADAT3',0
Simple mixer control 'PCM-ADAT6-ADAT4',0
Simple mixer control 'PCM-ADAT6-ADAT5',0
Simple mixer control 'PCM-ADAT6-ADAT6',0
Simple mixer control 'PCM-ADAT6-ADAT7',0
Simple mixer control 'PCM-ADAT6-ADAT8',0
Simple mixer control 'PCM-ADAT6-AN1',0
Simple mixer control 'PCM-ADAT6-AN2',0
Simple mixer control 'PCM-ADAT6-AS1',0
Simple mixer control 'PCM-ADAT6-AS2',0
Simple mixer control 'PCM-ADAT6-PH3',0
Simple mixer control 'PCM-ADAT6-PH4',0
Simple mixer control 'PCM-ADAT7-ADAT3',0
Simple mixer control 'PCM-ADAT7-ADAT4',0
Simple mixer control 'PCM-ADAT7-ADAT5',0
Simple mixer control 'PCM-ADAT7-ADAT6',0
Simple mixer control 'PCM-ADAT7-ADAT7',0
Simple mixer control 'PCM-ADAT7-ADAT8',0
Simple mixer control 'PCM-ADAT7-AN1',0
Simple mixer control 'PCM-ADAT7-AN2',0
Simple mixer control 'PCM-ADAT7-AS1',0
Simple mixer control 'PCM-ADAT7-AS2',0
Simple mixer control 'PCM-ADAT7-PH3',0
Simple mixer control 'PCM-ADAT7-PH4',0
Simple mixer control 'PCM-ADAT8-ADAT3',0
Simple mixer control 'PCM-ADAT8-ADAT4',0
Simple mixer control 'PCM-ADAT8-ADAT5',0
Simple mixer control 'PCM-ADAT8-ADAT6',0
Simple mixer control 'PCM-ADAT8-ADAT7',0
Simple mixer control 'PCM-ADAT8-ADAT8',0
Simple mixer control 'PCM-ADAT8-AN1',0
Simple mixer control 'PCM-ADAT8-AN2',0
Simple mixer control 'PCM-ADAT8-AS1',0
Simple mixer control 'PCM-ADAT8-AS2',0
Simple mixer control 'PCM-ADAT8-PH3',0
Simple mixer control 'PCM-ADAT8-PH4',0
Simple mixer control 'PCM-AN1-ADAT3',0
Simple mixer control 'PCM-AN1-ADAT4',0
Simple mixer control 'PCM-AN1-ADAT5',0
Simple mixer control 'PCM-AN1-ADAT6',0
Simple mixer control 'PCM-AN1-ADAT7',0
Simple mixer control 'PCM-AN1-ADAT8',0
Simple mixer control 'PCM-AN1-AN1',0
Simple mixer control 'PCM-AN1-AN2',0
Simple mixer control 'PCM-AN1-AS1',0
Simple mixer control 'PCM-AN1-AS2',0
Simple mixer control 'PCM-AN1-PH3',0
Simple mixer control 'PCM-AN1-PH4',0
Simple mixer control 'PCM-AN2-ADAT3',0
Simple mixer control 'PCM-AN2-ADAT4',0
Simple mixer control 'PCM-AN2-ADAT5',0
Simple mixer control 'PCM-AN2-ADAT6',0
Simple mixer control 'PCM-AN2-ADAT7',0
Simple mixer control 'PCM-AN2-ADAT8',0
Simple mixer control 'PCM-AN2-AN1',0
Simple mixer control 'PCM-AN2-AN2',0
Simple mixer control 'PCM-AN2-AS1',0
Simple mixer control 'PCM-AN2-AS2',0
Simple mixer control 'PCM-AN2-PH3',0
Simple mixer control 'PCM-AN2-PH4',0
Simple mixer control 'PCM-AS1-ADAT3',0
Simple mixer control 'PCM-AS1-ADAT4',0
Simple mixer control 'PCM-AS1-ADAT5',0
Simple mixer control 'PCM-AS1-ADAT6',0
Simple mixer control 'PCM-AS1-ADAT7',0
Simple mixer control 'PCM-AS1-ADAT8',0
Simple mixer control 'PCM-AS1-AN1',0
Simple mixer control 'PCM-AS1-AN2',0
Simple mixer control 'PCM-AS1-AS1',0
Simple mixer control 'PCM-AS1-AS2',0
Simple mixer control 'PCM-AS1-PH3',0
Simple mixer control 'PCM-AS1-PH4',0
Simple mixer control 'PCM-AS2-ADAT3',0
Simple mixer control 'PCM-AS2-ADAT4',0
Simple mixer control 'PCM-AS2-ADAT5',0
Simple mixer control 'PCM-AS2-ADAT6',0
Simple mixer control 'PCM-AS2-ADAT7',0
Simple mixer control 'PCM-AS2-ADAT8',0
Simple mixer control 'PCM-AS2-AN1',0
Simple mixer control 'PCM-AS2-AN2',0
Simple mixer control 'PCM-AS2-AS1',0
Simple mixer control 'PCM-AS2-AS2',0
Simple mixer control 'PCM-AS2-PH3',0
Simple mixer control 'PCM-AS2-PH4',0
Simple mixer control 'PCM-PH3-ADAT3',0
Simple mixer control 'PCM-PH3-ADAT4',0
Simple mixer control 'PCM-PH3-ADAT5',0
Simple mixer control 'PCM-PH3-ADAT6',0
Simple mixer control 'PCM-PH3-ADAT7',0
Simple mixer control 'PCM-PH3-ADAT8',0
Simple mixer control 'PCM-PH3-AN1',0
Simple mixer control 'PCM-PH3-AN2',0
Simple mixer control 'PCM-PH3-AS1',0
Simple mixer control 'PCM-PH3-AS2',0
Simple mixer control 'PCM-PH3-PH3',0
Simple mixer control 'PCM-PH3-PH4',0
Simple mixer control 'PCM-PH4-ADAT3',0
Simple mixer control 'PCM-PH4-ADAT4',0
Simple mixer control 'PCM-PH4-ADAT5',0
Simple mixer control 'PCM-PH4-ADAT6',0
Simple mixer control 'PCM-PH4-ADAT7',0
Simple mixer control 'PCM-PH4-ADAT8',0
Simple mixer control 'PCM-PH4-AN1',0
Simple mixer control 'PCM-PH4-AN2',0
Simple mixer control 'PCM-PH4-AS1',0
Simple mixer control 'PCM-PH4-AS2',0
Simple mixer control 'PCM-PH4-PH3',0
Simple mixer control 'PCM-PH4-PH4',0
Simple mixer control 'Line-ADAT3-ADAT3',0
Simple mixer control 'Line-ADAT3-ADAT4',0
Simple mixer control 'Line-ADAT3-ADAT5',0
Simple mixer control 'Line-ADAT3-ADAT6',0
Simple mixer control 'Line-ADAT3-ADAT7',0
Simple mixer control 'Line-ADAT3-ADAT8',0
Simple mixer control 'Line-ADAT3-AN1',0
Simple mixer control 'Line-ADAT3-AN2',0
Simple mixer control 'Line-ADAT3-AS1',0
Simple mixer control 'Line-ADAT3-AS2',0
Simple mixer control 'Line-ADAT3-PH3',0
Simple mixer control 'Line-ADAT3-PH4',0
Simple mixer control 'Line-ADAT4-ADAT3',0
Simple mixer control 'Line-ADAT4-ADAT4',0
Simple mixer control 'Line-ADAT4-ADAT5',0
Simple mixer control 'Line-ADAT4-ADAT6',0
Simple mixer control 'Line-ADAT4-ADAT7',0
Simple mixer control 'Line-ADAT4-ADAT8',0
Simple mixer control 'Line-ADAT4-AN1',0
Simple mixer control 'Line-ADAT4-AN2',0
Simple mixer control 'Line-ADAT4-AS1',0
Simple mixer control 'Line-ADAT4-AS2',0
Simple mixer control 'Line-ADAT4-PH3',0
Simple mixer control 'Line-ADAT4-PH4',0
Simple mixer control 'Line-ADAT5-ADAT3',0
Simple mixer control 'Line-ADAT5-ADAT4',0
Simple mixer control 'Line-ADAT5-ADAT5',0
Simple mixer control 'Line-ADAT5-ADAT6',0
Simple mixer control 'Line-ADAT5-ADAT7',0
Simple mixer control 'Line-ADAT5-ADAT8',0
Simple mixer control 'Line-ADAT5-AN1',0
Simple mixer control 'Line-ADAT5-AN2',0
Simple mixer control 'Line-ADAT5-AS1',0
Simple mixer control 'Line-ADAT5-AS2',0
Simple mixer control 'Line-ADAT5-PH3',0
Simple mixer control 'Line-ADAT5-PH4',0
Simple mixer control 'Line-ADAT6-ADAT3',0
Simple mixer control 'Line-ADAT6-ADAT4',0
Simple mixer control 'Line-ADAT6-ADAT5',0
Simple mixer control 'Line-ADAT6-ADAT6',0
Simple mixer control 'Line-ADAT6-ADAT7',0
Simple mixer control 'Line-ADAT6-ADAT8',0
Simple mixer control 'Line-ADAT6-AN1',0
Simple mixer control 'Line-ADAT6-AN2',0
Simple mixer control 'Line-ADAT6-AS1',0
Simple mixer control 'Line-ADAT6-AS2',0
Simple mixer control 'Line-ADAT6-PH3',0
Simple mixer control 'Line-ADAT6-PH4',0
Simple mixer control 'Line-ADAT7-ADAT3',0
Simple mixer control 'Line-ADAT7-ADAT4',0
Simple mixer control 'Line-ADAT7-ADAT5',0
Simple mixer control 'Line-ADAT7-ADAT6',0
Simple mixer control 'Line-ADAT7-ADAT7',0
Simple mixer control 'Line-ADAT7-ADAT8',0
Simple mixer control 'Line-ADAT7-AN1',0
Simple mixer control 'Line-ADAT7-AN2',0
Simple mixer control 'Line-ADAT7-AS1',0
Simple mixer control 'Line-ADAT7-AS2',0
Simple mixer control 'Line-ADAT7-PH3',0
Simple mixer control 'Line-ADAT7-PH4',0
Simple mixer control 'Line-ADAT8-ADAT3',0
Simple mixer control 'Line-ADAT8-ADAT4',0
Simple mixer control 'Line-ADAT8-ADAT5',0
Simple mixer control 'Line-ADAT8-ADAT6',0
Simple mixer control 'Line-ADAT8-ADAT7',0
Simple mixer control 'Line-ADAT8-ADAT8',0
Simple mixer control 'Line-ADAT8-AN1',0
Simple mixer control 'Line-ADAT8-AN2',0
Simple mixer control 'Line-ADAT8-AS1',0
Simple mixer control 'Line-ADAT8-AS2',0
Simple mixer control 'Line-ADAT8-PH3',0
Simple mixer control 'Line-ADAT8-PH4',0
Simple mixer control 'Line-AS1-ADAT3',0
Simple mixer control 'Line-AS1-ADAT4',0
Simple mixer control 'Line-AS1-ADAT5',0
Simple mixer control 'Line-AS1-ADAT6',0
Simple mixer control 'Line-AS1-ADAT7',0
Simple mixer control 'Line-AS1-ADAT8',0
Simple mixer control 'Line-AS1-AN1',0
Simple mixer control 'Line-AS1-AN2',0
Simple mixer control 'Line-AS1-AS1',0
Simple mixer control 'Line-AS1-AS2',0
Simple mixer control 'Line-AS1-PH3',0
Simple mixer control 'Line-AS1-PH4',0
Simple mixer control 'Line-AS2-ADAT3',0
Simple mixer control 'Line-AS2-ADAT4',0
Simple mixer control 'Line-AS2-ADAT5',0
Simple mixer control 'Line-AS2-ADAT6',0
Simple mixer control 'Line-AS2-ADAT7',0
Simple mixer control 'Line-AS2-ADAT8',0
Simple mixer control 'Line-AS2-AN1',0
Simple mixer control 'Line-AS2-AN2',0
Simple mixer control 'Line-AS2-AS1',0
Simple mixer control 'Line-AS2-AS2',0
Simple mixer control 'Line-AS2-PH3',0
Simple mixer control 'Line-AS2-PH4',0
Simple mixer control 'Line-IN3-ADAT3',0
Simple mixer control 'Line-IN3-ADAT4',0
Simple mixer control 'Line-IN3-ADAT5',0
Simple mixer control 'Line-IN3-ADAT6',0
Simple mixer control 'Line-IN3-ADAT7',0
Simple mixer control 'Line-IN3-ADAT8',0
Simple mixer control 'Line-IN3-AN1',0
Simple mixer control 'Line-IN3-AN2',0
Simple mixer control 'Line-IN3-AS1',0
Simple mixer control 'Line-IN3-AS2',0
Simple mixer control 'Line-IN3-PH3',0
Simple mixer control 'Line-IN3-PH4',0
Simple mixer control 'Line-IN4-ADAT3',0
Simple mixer control 'Line-IN4-ADAT4',0
Simple mixer control 'Line-IN4-ADAT5',0
Simple mixer control 'Line-IN4-ADAT6',0
Simple mixer control 'Line-IN4-ADAT7',0
Simple mixer control 'Line-IN4-ADAT8',0
Simple mixer control 'Line-IN4-AN1',0
Simple mixer control 'Line-IN4-AN2',0
Simple mixer control 'Line-IN4-AS1',0
Simple mixer control 'Line-IN4-AS2',0
Simple mixer control 'Line-IN4-PH3',0
Simple mixer control 'Line-IN4-PH4',0
Simple mixer control 'Line-IN3 Sens.',0
Capabilities: enum
Items: '-10dBV' '+4dBu'
Item0: '-10dBV'
Simple mixer control 'Line-IN4 Sens.',0
Capabilities: enum
Item0: '-10dBV'
Simple mixer control 'Mic-AN1-ADAT3',0
Simple mixer control 'Mic-AN1-ADAT4',0
Simple mixer control 'Mic-AN1-ADAT5',0
Simple mixer control 'Mic-AN1-ADAT6',0
Simple mixer control 'Mic-AN1-ADAT7',0
Simple mixer control 'Mic-AN1-ADAT8',0
Simple mixer control 'Mic-AN1-AN1',0
Simple mixer control 'Mic-AN1-AN2',0
Simple mixer control 'Mic-AN1-AS1',0
Simple mixer control 'Mic-AN1-AS2',0
Simple mixer control 'Mic-AN1-PH3',0
Simple mixer control 'Mic-AN1-PH4',0
Simple mixer control 'Mic-AN2-ADAT3',0
Simple mixer control 'Mic-AN2-ADAT4',0
Simple mixer control 'Mic-AN2-ADAT5',0
Simple mixer control 'Mic-AN2-ADAT6',0
Simple mixer control 'Mic-AN2-ADAT7',0
Simple mixer control 'Mic-AN2-ADAT8',0
Simple mixer control 'Mic-AN2-AN1',0
Simple mixer control 'Mic-AN2-AN2',0
Simple mixer control 'Mic-AN2-AS1',0
Simple mixer control 'Mic-AN2-AS2',0
Simple mixer control 'Mic-AN2-PH3',0
Simple mixer control 'Mic-AN2-PH4',0
Simple mixer control 'Mic-AN1 48V',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'Mic-AN1 PAD',0
Simple mixer control 'Mic-AN2 48V',0
Simple mixer control 'Mic-AN2 PAD',0
Simple mixer control 'IEC958',0
Simple mixer control 'IEC958 Emphasis',0
Simple mixer control 'IEC958 Pro Mask',0
Simple mixer control 'Sample Clock Source',0
Capabilities: enum
Items: 'AutoSync' 'Internal'
Item0: 'AutoSync'
