RME Babyface Pro FS Portable Interface Review
Was the 32 ohm measurement done with the 1/4" 11 ohm output impedance designed for high impedance headphones, instead of the 1/8" 0.1 ohm? The added edit makes me think it might've been. Probably not, but I'd like to know. 56mW seems pretty low - RME lists 90
Could you run an unbalanced phono preamp's output into the Babyface?
"IN3" and "IN4" appear to be stereo 1/4" (?) phone jacks for line level (unbalanced) inputs. @amirm describes them as
two analog inputs
on the first post of this thread.
So, presumably, yes, you could.
You'd need the appropriate cable to adapt from your phono preamp to this gadget, of course.
Great that RME is answering questions directly here! As they seem to be following this thread I dare to post my wish list for this almost perfect device:
i) USB-C in combination with a beefier headphone amp when USB-C is connected on the host. As stated by RME earlier in this thread, amp power was limited because of limited USB power on a portable device, this should be no problem with a USB-C connection.
ii) maybe a wider housing (or a UCX like housing) with most I/O on the back/front, so the desk can be kept tidy.
I am saving money already ;)
Yes, USB-C could provide more robust headphone output. It's one of the reasons I'm holding off getting the Babyface FS right now.
USB-C is not required to supply more power than traditional USB, and this is why most peripheral devices don't depend on it.
I tested one of my laptop ports, and it is able to supply 15 W, which is the maximum power without PD, so this much is probably not very rare. The peripheral device would have to adapt to the available power.
Yes, a 1 watt headphone amp is a power house. So not being USB C is not the restriction. I have a Babyface and find the headphone out adequate, but just. So it would be nicer if it had more power.
I was not very precise about using "USB-C" in my post, I didn't want to sound too technical. USB-C is the conector type and what counts for power is the USB standard. Power limitations exist for the different standards of USB i.e. USB-1, USB-2 and USB-3. As far as I know, the babyface uses the USB-2 protocol which is limited to 5V/500mA = 2.5W which IS limiting having in mind that it needs to supply enough power for the 48V phantom power (you loose some power in the convertors scaling up 5V to 48V), for the headphone amp and for powering the rest of the device (you'll also want some headroom so the babyface does not stop to operate because of missing power during a power usage spike when it is powering two 48V active mics). USB-3 opens up higher power capabilities (up to 3A) and USB-C is the most common cable type for USB-3. Of course USB-3 can work over type A/B conectors too. USB-3 is not needed for data bandwidth for a low channel count interface, but it is great for incorporating better headphone amps!
Indeed, USB power supply depends on standards.
... USB-3 is not needed for data bandwidth for a low channel count interface, but it is great for incorporating better headphone amps!
I don't know if they could do it with USB 2.0 but the Apollo Solo, as an example of a "low channel count interface", need at least a USB 3.0 connection to make it work, and it's not for power supply because you have to use it with a external power supply (and can't without it).
(it's a USB-C port but you can make it work with a USB-C to USB-A cable connected to a USB-A 3.0 port, if the cable if fully wired, and not all cables are...)
The Babyface also has a DC input jack for using a separate power supply. It's not needed for power rather for stand alone operation without a PC. It also has no trouble with 48 volt phantom power.
I know the babyface has a DC input jack, but it is a device that is designed to work with a USB-2 connection only. This limits the total available power, and this is why they can't include a powerful headphone amp. With USB-3 they could include a more powerful amp. I think the Audient id24 resolves this problem in a clever way. When a USB-3 connection is available they make more power available to the headphone amp, when only USB-2 is available this power is reduced. Julian Krause makes a remark about this in his video about the iD24.
Babyface consumes more power than the standard strictly allows:
  • Idle power consumption: 2.8 Watts
  • Typical power consumption: 3.7 Watts
  • Max. power consumption: 5.4 Watts
  • Current at 5 V bus power operation: 700 mA (3.7 Watts)
Even the idle consumption is more than the maximum power of USB 2 (2.5 W). The maximum consumption is more than allowed by USB 3. Apparently RME has tested their device and concluded that typical computer hosts can supply this amount of power – Babyface takes advantage of the de facto standard. Only iPad hosts are required to use an external power supply.
Now that I think of it I believe I've always had mine on USB 3.0 ports. Those have 4.5 watt output or 900 milliamps at 5 v. I suppose the 5.4 watt level must not last very long.
My Antelope Audio Zen Tour interface using a wall wart requires 25 watts. No USB power for it.
I recently got the Audient ID14 Mk2, which uses my computer's USB Type-C connection for power and data. No PS needed. I can attest that the headphone amplifier output is remarkably more robust than the iD22's HP output it's replaced. Better dynamic range too (125 db(a). I had hoped that the iD14 latency would improve, but the RTL at 48kHz/128 is 10.1 ms, just a little faster than the iD22.
RME Babyface FS still has the latency advantage of about 4ms running similar settings.
There a really many standards with USB. A USB 3 (type A) is required to support 900mA but most modern ports supply BC whch gives 1.5A. A USB C will give 3A at least (when using a C to C connection), but most ports supply 60W, which is obtained by negotiating higher voltages. It gets trickier with USB-A to C cables, here the upstream A port is the limiting factor. On the other side a USB-2 port can strictly _limit_ current to 500mA, such a port would probably require the use of the external PSU with the babyface at full power. These ports are not common any more, especially on modern audio PCs. RME specifies the babyface with 600mA, which is slightly above the USB-2 standard but will work in most situations without the PSU. This is a conservative design approach which will get you running with 99% of audio PCs, but by limiting the power consumption (and thus the headphone amp power). I personally would prefer a higher power consumption of the device with more power available for the headphone amp, and be required to use at least a USB port that can supply 7.5W or 15W. I'd guess eventually RME will adapt to the changes in host hardware to stay competitive. Their conservative approach has its positive sides too (stability and compatibility)!
same waiting for them to update the babyface to usb3 and also to make a black version.. The blueish is kinda ugly ngl
Hello!
I have a few questions about the outputs of the Babyface Pro FS.
I have several pairs of headphones and they are all low impedance around 32 ohms, but I use them through the TRS 6.3mm output because the sound is louder compared to the small 3.5mm output.
As far as I understand, although according to the specifications, the 3.5mm output has more power, it is 6db weaker in sound, also according to the specifications.
I listen or work at a moderate volume, I'm not sure but no more than 90 db SPL i guess.
Is it possible at these listening/working levels to get a change in the frequency response of the headphones?
I have the following headphones:
AKG K371 - Impedance - 32Ω, Sensitivity - 114dB
Steven Slate Audio VSX - Impedance - 37Ω, Sensitivity - 127mW
HIFIMAN HE400se - Impedance - 32Ω, Sensitivity - 91dB
Should I only use 3.5mm output for all my headphones or the HIFIMAN HE400se can I use them through 6.3mm output because of their lower sensitivity and constant impedance because they are planar headphones, please explain these details to me.
Thanks in advance.
It's an interesting conundrum. Looks like the 3.5mm is purely voltage-limited even driving 32 ohm loads. The 6.3mm has higher voltage output and gain but will run into clipping slightly below maximum 3.5mm level with such loads.
If you're using the 3.5mm, you can rely on the output being able to back up its voltage capabilities with current output, even at +7 dBu out (giving 90 mW into 32 ohms). Not so for the 6.3mm - if purely voltage limited, it would be able to dish out almost 220 mW into 32 ohms, rather than just 60 mW, so it's clearly current-limited first. You may have no other choice than using it if you are limited by gain, i.e. your digital levels are so low that you wouldn't reach the power limits of either output anyway, however you need to be aware of the possibility that you might run into clipping.
This interface is decidedly not primarily designed for driving insensitive planars - you can shoehorn only so much headphone power into a high-performance interface with a 5 V @ 700 mA total power budget. You're expected to be using the 3.5mm for IEMs or lowish-impedance dynamic driver headphones like your K371s, while the 6.3mm is a better fit for medium-high impedance models like 150-300 (maybe 600 ohm) Beyerheisers.
If push comes to shove and you find yourself running out of volume on the 3.5mm jack with your planars, you can always run it into an external headphone amp still. A Topping L30 II is hard to beat for the price. Then we'd be talking 2-3 watts, not mW.
Thanks for the reply!
When I use my HIFIMAN HE400se with 3.5mm output, I'm usually at about 40% volume, I very rarely listen at 50-60%, so in practice the volume is sufficient for me.
I started using only 3.5mm output.
Interestingly though, after repeated A/B testing between the two outputs, at the same volume levels, I can't hear a change in the headphone frequency spectrum, supposedly technically, if I use the 6.3mm output with 32Ω headphones, there will be a change in sound, especially at low frequencies.
