REW-Moving Microphone Method Help
QMuse
My MM measurements show little difference in the high frequencies between a single speaker and a pair. I bet a sweep from a single spot would tell a different story.
Yes, single sweep of both speakers would tell a different story.
Can you repost that graph without lowering response of both speakers (plz apply 1/6 smoothing)? I think you have phase cancellation here:
DanGuitarMan
Jersey City, NJ
I might have recorded these in different sessions while changing the gain. I'll double check.
DanGuitarMan
Jersey City, NJ
The Left and Right were recorded one after another. Then the gain was adjusted down for the measurement of both. I aimed for 75dB for each measurement.
QMuse
You can adjust your current graph easilly: make your left and right channel overlapped at HF and increase both channel response 3dB higher than L and R at HF.
DanGuitarMan
Jersey City, NJ
I am using subtractive eq to tame peaks, and a maximum of 3dB boost to fill in dips. They are shown with psychoacoustic smoothing, but you get the idea. Here's a corrected response and the eqs applied:
DanGuitarMan
Jersey City, NJ
Here it is with Var smoothing so you can better see the huge dip at 55Hz. I always chalked this dip up to room/speaker interaction and never tried to boost it. When I tried, I wasn't satisfied.
QMuse
Do you have measurement of Both speekrs response with correction to add to that graph?
That dip may be due to speaer's positoning as well. Do you have a photo to show position?
DanGuitarMan
Jersey City, NJ
If phase of left and right speaker would be matched the response would look like this:
Unfortunately you cannot correct phase with PEW filtering, so re-positioning the speakers may be your only option. How close are they to the walls/corner?
DanGuitarMan
Jersey City, NJ
Thank you! I'd love to try that. There are a few impediments: 1. WAF 2. We have a corner mounted TV that swings out and would cover the speaker if I were to do that.
