Yes, I did it again, same results
Approx a 30cm sphere
The one-point measurement is the other graph you can see in my screenshot
Am I doing anything wrong or the MMM is not really to be used for measuring below 200Hz?
MMM is very accurate in low frequencies. Something strange happened in your measurement.
The problem with RTA measurements is that they are susceptible to noise
yea, the sweep was introduced for a reason.
personaly I see no advantage of the MMM whatsoever.
I once took several meassurements to the left, and to the right. the average matched the 1 center meassurement with the var filter
way faster
how many times a year do you take those meassurement though?
this is an issue for PA setups, not for home aplication
Play pink noise through your regular payback chain with DSP enabled, and measure with REW's RTA.Hi All,
Just trying to get familiar with measuring and creating filters and have a hit a roadblock.
I have Moode 7.2.1 with CamillaDSP running on RPI4, USB to Topping E30 DAC.
Using my Mac and RCA cables to my amp, to run REW MMM and export WAV file filters then import into CamillaDSP. This process functions correctly.
My problem is how do I remeasure in REW with the filters applied?
How do I perform the measurements as the REW sweep signal is coming from the Mac not via the RPI with the filters applied.
Can I apply the filters REW creates on my Mac and retest from within REW?
Am I being stupid, I'm confused?
Thanks for any advice.
Ian
Thanks thats helpful, create a sweep file for each channel and use a timing ref on one.The principle still stays the same. But you manually start the measurement sweep on your RPI, and configure REW to start the measurement using the acoustic timing reference.
