OK, my bad. I think SMSL is honest about it.Is there a SMPSU inside? They mention a toroidal transformer, so sounds like probably not?
It is a very common practice for all audio gear to be measured with a-weighting. It improves the specs. And it sort of attempts to match our hearing sensitivity. It doesn't do a perfect job and hence the reason I don't show it but the precedence in the industry is quite strong.Based on my reading on it, a-weighting is something you use for speakers or measuring noise levels for work safety. Why in the world one would use it on a DAC?
The amplitude of the sidebands is different so not jitter.But in the same 48kHz J-Test, USB unbalanced has 8k and 16k noise (probably not jitter?)
Now for design verification, you definitely do not want to use it. That is a different situation than marketing specs for a product.
It will be interesting to do. I will of course buy it if I damage it.Amirm do you want to do a teardown? I don't mind as long as it still works afterwards.
I find their demeanor so far to be quite open and nice, showing full screen-shots and such (compare that to what Schiit has done). So I prefer that we don't go there.Interesting. I found it suspicious SMSL folks were resistant to turn the HF filtering off here, sounds like it is a known issue to them.
My sense is that it is internal since I see that changing the sample rate changes the signature.
I think they did not catch it because they were always testing with a-weighting. Hopefully they are seeing it now and they can do the proper diagnosis.
Here you go. One is the converted balanced to single ended (SE) and the other, straight unbalanced:@amirm, can you test one leg of the balanced output? If CMR is done inside the unit running from one leg can be a (cheap) workaround for those w/o balanced downstream gear.
The converted signal ended is clean.
Nice, thank you. So seems like if one must use this DAC with SE amps a cheap XLR to SE adapter is the way to go.
Does it mean the problem is in the SE leg of the board? In that case would it be V/I converter?
Or you simply listen to 44.1 kHz.
I suspect the SE output is taken directly from the DAC, and balanced are actually op-amp summed first and then rebalanced again. We've been told DAC chip outputs can contain a lot of common mode junk.
The problem exists there too as Amir mentioned, the dashboard had 20kHz bandwidth so just not visible there.
