Should I get a balanced dac because benchmark said so
Not really, unless you want to use longer interconnects. Although, worth mentioning that DAC chips are outputting balanced analogues signals, so creating balanced outputs is only a matter of final costs, because it requires more active and passive components.
L.E.: Most of Amir's measurements on balanced DACs the balanced output was measuring a bit better than RCA output. So, as a general rule, balanced output generally will measure a tad better than non-balanced output. However, under some circumstances (due to the manufacturing process) this rule might not apply in 100% of the cases.
