Review and Measurements of Crown XLS 1502 Amp
Jstodda
Update: Just completed the bridge to each speaker. After a few calibrations there is a quite noticeable kick to midbass and lower frequencies. With any type of super dynamic music (ants marching live by Dave Matthews) everything seems much more full and balanced.
This is in pure direct mode from the Yamaha. I would say there is enough impact to warrant the purchase. Now if this would be substantial enough vs a 2502 bridged (440w) I don't know.
Thanks for all the feedback everyone! These speakers are HUNGRY at strong volume.
maxxevv
Hello, I'm new to ASR (this is my first comment).
Amir, could you run a few tests in bridged mono for me? My speakers have a peak handling of 600W and are 86db efficient; I wish to know if a pair of 1502s will be able to handle them without issue or if I need to step up to the 2002/2502.
I see that their thd shoots up well before 500W and I'm hoping that running them in bridged will eliminate that.
In bridged the 1502 is rated for 1050 W. How about we see how close it gets to that?
Its been a year since the original review.
Guess you missed out the second sentence in the review... The set was a member's loan.
Pandemonium
South Carolina
Ah, I see.
Hmm, I see there is a review for the 2502 up here as well. I'll go read that and make a decision.
Either way I'll end up with 2 crowns in bridged-mono. Once I have everything setup I'll come back with my thoughts.
bigbag34
Wish I was in Florida
Hi I am new to the forum. I have browsed for a while and the info here is super interesting. I have a subjective opinion to share, even though this site is scientific. I like the science of this site and was curious how something that measure poorly compares to something that measures OK. Again all of this is subjective and certainly influenced by my room, my past experiences and other factors.
Current system is Emotiva PT-100 preamp, Nuforce STA 200 power amp, JBL Studio 580 speakers and Klipsch Gate as my streamer from Spotify Premium or my Sony ES CD player from the 90's. I'm young, married for less than a few years and two little daughters so my budget is tight.
Based on this forum I purchased a Crown XLS 1502 to swap into my system. Just purchased it last night from Guitar Center, only have about 2 hours on it. I know the STA200 measured poorly, but I really enjoy it. It replaced a Harman Kardon HK3490 stereo receiver, Marantz PM6005 integrated amp, an Emotiva Basx A300 stereo power amp, and a NAD D7050. To my ears the STA200 sounded better than all those other amps.
1.) Even with nothing hooked into the RCA inputs on the Crown there is a hiss from the JBL's. I tired plugging it into a different outlet on a different circuit, hiss was exact same. Not sure if this hiss matters or not. The Nuforce STA200 by comparison is silent at idle, even with the preamp on. Again, the hiss might not matter at idle and might be "drown out" once the music starts playing.
2.) WOW, power! The bass response of the JBL's is much improved with the XLS 1502. Tighter, deeper, more, better :)
3.) Soundstage and separation of instruments seems to compare well to the STA200. I don't really notice too much difference between the two.
4.) At louder listening levels the XLS 1502 separates itself IMHO from the STA200. The XLS 1502 stays completely composed and doesn't sounds compressed compared to the STA200 which runs out of gas.
5.) The XLS 1502 is a lot "brighter" than the STA200. I have the treble on the PT100 down -3 for the 1502. I have to tweak my speaker position and maybe the XLS 1502 will benefit from some break-in, but initial impression is a little bright and fatiguing.
6.) The STA200 being class AB and using Exicon Mosfets in the output certainly measures a lot worse than the Crown, but so my ears prefer the sound of the STA200. I will be giving the XLS 1502 more time, and tweak my speaker position.
I posted some Youtube videos on my channel if anyone wants to see my set up.
Panelhead
I have a XLS-1500 and XLS-2000. Do not use the attenuators, feed from a dac with volume control. Both are silent if connected up balanced. Both have the hiss when connected using the RCA inputs.
I have heard that really well shielded cables are immune to noise pickup using the RCA inputs. All the balanced cables tried were silent.
Try this if possible to see if balanced connection eliminates the hiss.
Also try the Speakon connectors. They are more work. But ease of use is light years ahead of bare wire, spades, or bananas.
bigbag34
I'm getting hiss with nothing hooked into the RCA's. I have the amp on and speakers hooked up, nothing going into the RCA's. As I turn the level knobs on the XLS 1502 the hiss changes in intensity. Maybe with no inputs hooked up, it's trying to pull from the RCA's (if that makes any sense)?
Hooking up the Emotiva PT100 preamp via RCA's doesn't change the hiss at all, even while adjusting the volume on the PT-100.
DonH56
Monument, CO
All amps have a noise floor and the volume control often modulates it. High-sensitivity speakers, close seating, and high-power amps is a combination almost guaranteed to exhibit hiss. (Not saying that is your situation; I do not know.) Pro amps, particularly lower-end models, are designed to provide lots of power for the dollar so have fairly high gain and SNR is usually not stellar. The result is hiss. If the hiss is not objectionable at the listening position, ignore it. If it is, you'll likely need a different amplifier.
Panelhead
It definitely is not a high end product. But can be fine for listening.
The fact the hiss is constant whether the preamp is connected not not does not sound right. The reason is;
When testing an amplifier for noise floor the input should be shorted to ground. Usually a component plugged in does this also. Same when a test device like Amir’s AP.
The fact that is has no effect may be the output of your preamp. Do you know if it is AC or DC coupled? The presence of a coupling cap on the output of the preamp would prevent the low output impedance of the preamp from shunting this input.
This amplifier was made for the professional market. The low cost pro market. All pro gear is balanced. Mostly balanced only.
The RCA inputs were added for consumer use. But seem to be less than optimal. Every comment I have seen about hiss or other noise was from users connecting to the RCA inputs.
I have never hooked up the speakers to a Crown XLS without a source connected. Mine may have the same hiss.
DonH56
Monument, CO
If the input goes straight into the volume control the hiss might not change much. At max gain the Crown probably has the highest noise, but connecting a source at that level means the source noise also sees max gain so that might wash out the lower source driving impedance.
bigbag34
My main concern was whether or not that idle hiss was affecting fidelity or sound quality. I'm choosing to ignore it since it seems like once source material is playing, it's above the noise floor and has no effect on the sound quality at my listening position which is 10 feet away.
The XLS 1502 100% seems to bring out more fidelity and texture to the sound than the STA200. The only trade off I'm experiencing so far is that the center image of the XLS 1502 isn't as pronounced as it was in my set-up compared to the STA200 or my Marantz PM6005. I know I'm playing with budget gear but obviously I'd like to optimize my cheap gear and sometimes that means turning a blind eye to the shortcomings. Thanks All!!!
Reactions: wje
Panelhead
The “hiss” would be a deal killer for me.
One idea, try plugging the digital player into one channel and the preamp into the other. See if this effects the noise level with no music playing.
bigbag34
Hiss still present with Klipsch gate analog out directly into crown analog inputs. I guess between the hiss and the difference in center image I’m going to box it up and return it. I know it measures worse and has less power but in my system the STA200 is the clear winner - no hiss, holographic sound stage and very locked in center image. I wonder why the measurements were so poor for the STA200? Maybe I prefer crummy gear? Wish I had never seen measurements for the STA200 I probably would have been happy with it for a long time.
Maybe my xls 1502 is defective. With the amp on I put my ear right to the chassis and the amp itself has a slight hiss almost a sizzling sound coming from somewhere inside. I’m not surprised that that is manifesting itself through my 90db efficient JBL 580’s.
Mr. Malbolgia
Forgive me for asking, but how are these wattage numbers possible? I have the Crown XLS 1502, and the power supply states 250W consumption. How is that they are measuring at 271 per channel continuous?
Can someone walk me through how this (or any amp) can output more than it's power supply provides?
I see these ratings everywhere, and it seems like it's a bit of snake oil.
sergeauckland
Suffolk UK
The rated consumption is for normal operation on speech or music, where the average consumption is much lower. Maximum continuous sine wave power will result in power consumption numbers much higher, in line with theoretical predictions based on mode of operation and the resulting efficiency.
S
Chrispy
PNW
Sure, soon as you come up with the spec behind the "250W consumption".
Mr. Malbolgia
It’s labeled on the unit itself, right above the plug. 250 watts, and the 2502 has a stamp of 425 watts.
Neither unit has an amperage draw rating. Now, I’m curious about this because if we assume 80% efficiency the power supply would need to draw close to 11 amps to hit 500 watts.
Do we assume that each of these amps is capable of pulling a full 15 amps through its 250 Watt power supply to achieve rated output?
I ask here, because there seems to be quite a bit of knowledge on these forums, and I am genuinely interested.
I own two Crowns, a 1500 and a 1502.
Chrispy
PNW
It's not a max consumption spec nor a power supply spec....you need to know what the basis of the consumption spec for it to be meaningful.
Mr. Malbolgia
S
Does that mean that this power supply is able to pull more juice from the wall than what it is labeled for? Do you know how I could find out the amperage rating at full draw?
I have quite a bit of audio equipment, and the only stuff I have that actually seems to be pulling what it claims to be from the wall is an Onkyo TX-SR876 that actually tells me in the literature how much power it can pull in (9.8 amps) and my subs, which also have the same level of detail. everything else seems to dance around the real numbers.
I mean, nothing in pro audio seems to be spec’d the way it was twenty years ago either. I checked out some old Crown manuals, and they have every number laid out, with no inflation.
Again, looking to learn from this community. These reviews seem to be pretty clinical, and I don’t understand some of it, but power claims have been getting crazier for years.
Chrispy
PNW
Fan maybe for the physical sound from the amp, but why would that manifest itself in the output of the amp particularly?
