Revel Salon2 vs Genelec 8351B - Blind Test Preparations
Juhazi
Finland
About testing mono vs stereo,
I think that stereo sets unique requirements considering directivity (making imaging) which sadly are very much a matter of personal preference. Room size and wall materials play roles roo.
Here in Finland (home of Genelec) smooth and highish directivity is in very high regard among hifists and diyers. It minimizes room effects above Schröder, but is however difficult to achieve in midrange and bass. If directivity is well controlled, eq is easy. Genelec speakers have smooth but only modest DI. Horn speakers are the extreme, best examples are Synergy horns and some diy multihorn or cardiod bass projects.
Personally I love my dipoles more than any other type of speakers I've heard, because of the more diffuse but very natural imaging and tonal balance achieved with dsp. But most hifi-friends want more tight imaging and sharper transients.
Commercial speakers are nowdays often in multichannel systems and good stereo imaging is not important. Stereo loudspeaker setups are a curiosity, only for freaks with very individualistic preferences, so it is difficult to give recommendations and quantify universal preference.
CDMC
I’m open for donations of such apparatus :D (Complete with the necessary acoustically transparent but visually opaque curtains, electromechanical automation, controls, and end-to-end installation work, etc. necessary for it to be practical.)
Otherwise I will have to find the least bad compromise.
Don’t forget the dedicate test facility. :D
CDMC
Reproducibility.
Good science means your test should be reproducible by others.
He isn’t doing a peer review study, he is doing a comparison at home and trying to minimize variables.
watchnerd
Seattle Area, USA
My seats in the local symphony are in center, row U.
Every time I go, I'm reminded how diffuse things are. If I close my eyes, the "imaging" is not particularly tight, and the transients aren't particularly sharp, when contrasted with stereo on direct radiator speakers.
watchnerd
Seattle Area, USA
I get it -- the thread title is tad misleading.
It's a listening party / shoot out, with no implications beyond that localized event.
That's cool.
Chromatischism
Thanks for this, not having been to one myself (yet!).
Laser-like center imaging can be a neat effect at home, particularly if not using a center channel speaker, but if it comes at the cost of soundstage and speakers disappearing, I'm not sure it's a good trade. Might be a subjective call. If you have speakers that can do both depending on toe-in, it's worth it for people to experiment with.
watchnerd
Seattle Area, USA
I actually don't hold up live music as the reference standard for home hi fi reproduction.
BenB
Virginia
Personally, I like the center of row D in my local symphony hall. The soundstage is wide and precise and transients are sharp and impactful. When I used to play, I liked the sound from on the stage better than the sound in any seat (even if I was playing/listening from the back of the 2nd violins). Despite my preference for being up close, I still prefer wide horizontal dispersion from a speaker. Having tested wide horizontal (and narrow vertical) directly against narrow horizontal (and wide vertical), I don't recall the precision of the imaging being hurt by the wide horizontal dispersion. The soundstage was just wider (and more engaging / authentic). The discrepancy was large enough that in comparison, a narrow horizontal dispersion sounded almost mono. Perhaps a speaker with narrow vertical and narrow horizontal dispersion would have more precise imaging, at the expense of soundstage.
aarons915
Chicago, IL
That's cool.
Not really, he is trying to make the comparison as fair and free of bias as possible is the way it reads to me, however people take this way too seriously in my opinion. I do detailed comparisons when I try out new speakers myself, I level match, listen to a single speaker in mono and have done sighted and blind. I've never had a different outcome in a blind vs sighted comparison but I'm not really a brand guy and @echopraxia doesn't sound like one either with all of the different speakers he's bought. I personally think many people think the most minute of details is going to render a comparison useless and I don't agree with that, as long as you make an effort to make a fair comparison the results should be somewhat relevant to people. On the other hand, if he doesn't construct a Harman MLL lab with an automated shuffler it also gives people in denial cover to dismiss the test and save their ego, a win win.
DJBonoBobo
any germ
Ok, here are measurements with no sub, 1/24 smoothing, 10hz - 22khz:
Revel Salon2:
Genelec 8351B:
What useful info do you think a listening test between these (as such) would conclude?
This is an interesting thread. It makes it clear how important it is to clarify which hypothesis or which question you actually want to check with a test. This seems to be not so easy in this case, because many questions are already answered by the existing measurements.
When I see these measurements, my thought would be:
The Genelecs are not in optimal position because there are nasty dips in the bass (60 and 100 Hz). If I had the Genelecs and I could not position them differently, I would definitely add one or two subs.
The Revels on the other hand look very good in the bass, probably because of the more favourable position of the drivers in the room. All you need here is a bit of room EQ.
Therefore, I would be interested in a comparison "8351B + Sub" vs. "Salon2 without Sub".
For me personally, such a comparison is also a question of how a very good studio monitor plus sub (= more or less reasonable/rational in price, professional tools etc.) compares to one of the best floorstanding loudspeakers from the high-end world that is considerably more expensive, especially since you also need a matching amp.
For me personally, the clear prejudice would be that the concept of "excellent active coax monitor plus subwoofer" would have to be superior even to the best passive floorstanding loudspeaker. But there is certainly also the opinion that a good floorstanding loudspeaker would be preferable to such a combination.
Your first report goes in the direction of the Revel possibly having advantages that are not so obvious from the measured values. But maybe this is simply due to the better bass foundation? I don't know, of course, but that might be an interesting question to look into
Duke
Princeton, Texas
In other words, let’s say the Genelec 8351B and Salon2 preference becomes less different (or reversed even, due to the Salon2’s preference being due to soundstage overpowering the other superiorities of the Genelec) when listening in mono. That doesn’t actually make the Genelec any more preferred because I and every audiophile I know does not listen to music mono on a single speaker.
No, but doing the comparison in mono would be an interesting (to me at least) data point relevant to how strong the correlation is between speaker preference in mono and speaker preference in stereo. I suspect the Revel's wider dispersion would, if anything, widen the gap between the two in mono listening.
And I don't care that your listening is sighted. At the risk of committing localized blasphemy, I think controlled sighted listening can be an extremely useful tool.
watchnerd
Seattle Area, USA
Varies immensely by hall.
For Seattle Symphony, in Benaroya Hall, I don't like the closer seats. I get too much violin and not enough everything else.
Plus I don't like seeing the conductor's butt crack.
AudioJester
I was hoping you would do the listening tests. Be intetesting to see what the average punter could do in our own rooms/homes.
This is sure to enrage the critics, but was also going to ask if you could record the sesion and put it up on youtube so we could all participate.....
watchnerd
Seattle Area, USA
Using an iPhone microphone to record it?
I don't think those go down to 20 Hz.
March Audio
Albany Western Australia
Fast back and forth switching is not possible, but it should be faster than the speaker change in the Harman tests.
This is my biggest criticism of Toole and Olive's research, who have developed a sound evaluation algorithm for free-standing loudspeakers with mono signals.
Many people who start with loudspeaker development make the mistake of tuning their first self-developed loudspeaker individually, standing freely in the room, with a mono signal - speak from experience ;)
If both loudspeakers are then listened to in stereo in a normal listening room, they sound much too bright.
Would even go so far as to say that if a speaker standing freely in the room sounds optimal with a mono signal, it's a crossover mismatch.
Anyone can easily check this by placing a speaker freely and adjusting a mono signal with an equalizer so that it sounds optimal (at about 85dB) at the listening position and then listening to the stereo setting.
I have not found this.
Anyone can test it out. By your logic a pair of speakers that sound good in stereo will sound dull if used in mono. Anyone can test this out for themselves at home.
Secondly they haven't developed an algorithm to "set" the sound of a speaker in mono and free standing.
They have analysed people's preferences and found that people like a certain sound. This happens to be a flat anechoic on axis response with smooth off axis response. The algorithm correlates the objective measurements to the observed preferences to allow prediction of what speakers people will like.
richard12511
Probably very long post incoming. Apologies in advance.
First of all, thank you so much for this. This blind means so, so, so much to me! These have literally been my end game dream music speakers for the past 5 years. I had already somewhat resigned myself to the fact that I'd probably end up having to waste a ton of money by buying both of them to do a blind comparison myself in order to truly be satisfied with my decision. Measurements are great, but blind tests are king for me. I bought my current mains(JTR Reference series) based entirely off blind tests(one that I attended, and one that I read online). There were no measurements at all of the JTRs at the time, but that's how much faith I place in blind tests. Given the price of these speakers, I figured the odds of 1. Someone having both speakers, and 2. Being willing to setup a blind match between them, was basically zero. The fact that you're doing this comparison here has the potential to save me a ton of money if one ends up winning convincingly.
I do have some suggestions based on my past experience with hosting 4 blinds, and attending 1. Hopefully these suggestions don't come across as criticism. I just care deeply about this particular blind, and so there's a lot of passion. Ultimately, only consider the suggestions that you're completely comfortable with, as no matter what you do, I'll be very grateful that you're doing it in the first place.
1. Do not tell the participants ahead of time ahead what speakers are going to be involved in the test. This greatly diminishes the value of the test. This was by far the biggest critique of the M2 vs Salon2 blind that was done on AVS, and many people disregard it completely for this reason.
2. Don't do an ABX text. Do a preference test. ABX is more useful for electronic equipment, but we know for a fact that speakers can sound very different.
3. Consider adding a third speaker. Adding a third speaker (ime) makes it harder to identify individual speakers and gives you another reference point, and it's also the recommendation of Harman and Floyd Toole. Further, if it's a speaker of lesser quality, it might help to differentiate these two beasts some in terms of ratings. For both the stereo and mono tests I hosted of the JTR 212 vs Revel M105, we used an Infinity Beta 20($400/pair when I bought them) as the third speaker. You could maybe add your Sierra towers into the mix? If the Sierras by some chance end up beating the Genelecs, it may shed further light on the mono vs stereo debate. BTW, not saying the Sierras are bad or comparable to the Infinity Betas, but the other 2 speakers are SOTA.
Problems #2 and #3(if not accounted for) combined together can make it very easy to identify the speakers, even under blind conditions. It's part of the reason I no longer participate in the blinds I host with friends. I can easily identify all my speakers. Adding a third speaker and not telling them what speakers are under test makes it almost impossible for anyone(but you) to identify them.
4. Mono vs stereo. I think this is going to be a very hot topic. There's most likely gonna be lots of debate back in forth, and no matter what you choose, half of the people are gonna say your test is useless :(. Do what you think is most logical.
I'll share my plebeian thoughts on the topic based on reading Floyd's book, reading the actual Harman studies, reading great forum threads on AVS, and doing my own mono vs stereo vs multichannel blind listening test at home. My overall knowledge and understanding of these topics is far below many others on this forum.
The Harman view is that mono vs stereo doesn't matter if the sample size is sufficient. The results will be exactly the same, but you'll need a larger sample size with stereo to come to a meaningful conclusion. Imo, this is a valid interpretation of the data represented in the study, but there are also other valid interpretations.
Looking at the study, the Quad's which have very narrow dispersion(and presumably the best imaging) sounded terrible in the mono test, but were very close to the others in the stereo test.
The Harman interpretation was that the Quad's improvement from mono to stereo was due to the fact that its flaws were more hidden in stereo. But, another interpretation of that data might be that the Quad's strengths, namely imaging, were absent in the mono comparison. I see no reason why this latter interpretation is any less valid than the former. In my opinion, more research is needed to settle the mono vs stereo debate. Even Toole admits that increasing the number of channels decreases the preference for wide dispersion(don't remember if this was in his book or a forum post).
Personal anecdote on this topic:
As mentioned earlier, one of the first blinds I hosted was a JTR 212 vs Revel M105 vs Infinity Beta 20. This is the only blind where I've ever done a mono vs stereo vs multichannel test, and the results were very enlightening.
In the mono test, the M105 was preferred overall by 3/3 people and preferred on ~80%+ of the tracks. The JTR actually came in last, losing slightly to the Infinity Beta 20.
In the stereo test, the JTR was preferred overall by 3/4 people(we had an extra person after the first day), though admittedly less strongly than the Revel was preferred in mono(I think it was high ~70%, but I don't remember exactly). The JTR also dominated the Infinity in the stereo test.
In the multichannel test, the JTR basically stomped, winning 4/4 overall and only losing 6 times total amongst 104 trials(26 tracks x 4 listeners). It also beat the Infinity Beta 20 104/104 times, and this was in spite of the fact that the center channel was an Infinity Beta C360, and the rear and side surrounds were Infinity Beta 20s. I've since acquired a full JTR surround setup, but this was before, when I just had the front L/R.
Based on these results, I'm fairly confident in saying that the mono vs stereo Harman view doesn't hold for my room. Whether or not that applies to other rooms and speakers, I don't know. As for why it applies in my situation? I don't know for sure, but my current best guess is that it's due to the difference in dispersion width of the speakers. The JTR is +/- 30, and the Revel is +/- 70. I'm not sure what the Infinity is, but I can tell it's closer to the Revel than it is the JTR.
All that said, I don't think the mono vs stereo factor will be as big as a problem for your test as it was for mine. I was comparing a +/- 30 speaker against a +/- 70 speaker. At +/- 60, the 8351b is still a wide dispersion design(the M2 is ~+/-50) in my view. We don't really know the Salon2's horizontal beam width, and we won't until @amirm measures it(side note: I'd be willing to donate money to help @amirm hire movers to move it downstairs and back up), but I would ballpark it in the range of my M105's. So, for you're test, we're probably comparing a +/- 60 dispersion width against a +/- 70-75 dispersion width(and maybe a bit wider if you include the Ascends ;)). I don't think it will be a huge factor in which speaker wins.
If I could get anything I want, I'd want you to do both a mono and a stereo test. Regardless of the results, I think it would be hugely beneficial for audio science. If the same speaker wins both tests, it would add credence to Harman's view that mono vs stereo doesn't change preference. If different speakers win, it would add credence to the notion that more research needs to be done exploring the effects of dispersion width and the relation to the number of channels.
Off topic: I plan to do the mono vs stereo vs multichannel test again(maybe after covid) with my now better knowledge and experience of hosting blinds. I'll probably start a similar thread to this one to ask for advice. The plan is to have the JTR 210 vs Infinity Reference 263 vs Revel M105 vs JBL 308p vs Genelec 8030c, but I still need to find a good way to switch between active and passive speakers.
In order of my personal preference for testing, I would vote:
Mono and Stereo test with subs > Mono test with subs > Mono and stereo test without subs > Stereo test with subs > Mono test without subs > Stereo test without subs.
5. Ask each participant to keep score on a 1-10 scale. We did this for the first blind test I hosted, but stopped doing it after that because it was hard, and the ratings were very inconsistent. I now really regret that we stopped doing it.
6. Have people take notes on what they like/dislike. You did this for your last blind, so I'm guessing you already have this in the plan.
7. Consider again the idea of placing the speakers more optimally. Ideally this would place the Genelec on a stand with the tweeter at ear height at 35" or so, and the Salon2 on the ground with its tweeter at 49"?. Nothing can be done about the Salon2 tweeter being too high(except a long listening distance, which you have). The Genlec though can be optimized better with extra work. Currently you've got the Genelec with a tweeter height of 58"?. Angling it down does help(imo), but it also takes the speaker beam off parallel with your ears, which comes with other disadvantages. Going with what you have I think will be mostly ok, but equal ground would be more optimal. Some may choose not to value the blind because of this. Personally, I don't see it as a huge deal.
FWIW, the two blinds I've hosted with my biggest towers(155lbs), we had 2 guys standing ready to lift the speaker and carry it backwards, and one guy to move the bookshelf + stand into place. We never had very much trouble with that setup. 155lbs in the shape of a tall skinny box is surprisingly light for 2 guys to lift and carry 2ft back. I've also recently been picking up and moving the speaker(about 6ft back) by myself almost every day to give myself more room for playing with my VR headset :D. It's 9lbs heavier than the Salon2, so it can be done, though I admit it's hard(you really have to commit). The way I've found works best is to get behind the speaker, wrap my arms around and grab the front(not on the drivers), bend down to pick up the speaker with mostly my legs and back, then lean back(with it resting against my inclined chest) to walk with it. That said, my speaker has a truck bed finish, so I don't have to worry about damaging(or fingerprinting) the cabinet, so the Salon might present an additional challenge.
It may not be worth it for you, though, and I don't begrudge you for that. Better to do it sub-optimally than not do it all, I say. Above all, I'm still immensely grateful that you're doing this.
8. On EQ. Please, no matter what, don't let people talk you into not EQing below the transition frequency. We know for a fact that below 100Hz, we're not listening to the speakers. Below 100Hz, we're listening to the dimensions and material of the room, and the placement of the transducers within those dimensions. The goal of this test should be to test the speakers themselves, not the speaker placement. If you don't EQ below the transition frequency, you're not testing speaker A vs speaker B, you're testing placement A vs placement B. That latter is still useful, but it's only useful for those who have the exact same room as you(which is probably no one but you).
9. On subwoofers. Please use subwoofers!!! Don't let people talk you out of this. Not using subs would make it a cake walk win for the Salon2 at critical listening levels(especially at 20ft). Given that we know bass is 30% of the battle, it would make the test basically meaningless for those of us who use subs. Whether I end up buying the Salon2 or the 8351b, I'll be crossing them over to 4 JTR Captivator RS2s at 100Hz, so I have zero care for which speaker has better bass. If you don't use subwoofers, you have to do a hard cutoff of everything below 100Hz or so, but even that will be far less useful than how they integrate with subs.
10. If you do decide to do a stereo test, don't do it the way Harman does. Harman, puts the speakers in the exact same spot with the same toe in, and it's the biggest reason why I don't consider the Harman stereo tests as all that valid. This was the way I did my first stereo blind test, but I'm now of the opinion that it's a flawed method of testing. Different speakers in a stereo pair will require different amounts of distances between them, and different amounts of distance from the listener to achieve optimal imaging. The reason Harman does it this way is most likely because they have an automated speaker shuffler and they have to do it this way(designing a more sophisticated shuffler would be much harder and expensive), but it's definitely sub-optimal(imo). Doing it this way has a decent chance of leading to incorrect results.
For example, my M105s sound and measure best about 10.5ft apart, 10.5ft from the listener, and toed in directly on axis. My 212s sound and measure best about 12ft apart, 12ft from the listener, and toed in to cross 3-4 feet in front of the listener. My JBL 308/5ps sound and measure best pretty close to where the Revels do, but aimed straight ahead. If I measure stereo pair A in the position that stereo pair B sounds best, stereo pair B will be at a major advantage. If I measure stereo pair A and B at a random location, the stereo pair with wider dispersion will be at a major advantage, as wide dispersion designs are far more tolerant of positional changes.
In my experience, it takes a solid week's worth of work of moving, listening, and measuring to figure this all out, and given that most people don't do this(including the Harman shuffler), it's a big reason why I much prefer a mono test over a stereo test.
The way we've accounted for this so far is that we'll place colored tape(silver, yellow, purple) on the corner of each speaker top, and 4 pieces of the same colored tape at the base of each speaker to mark its position and toe in. It's easier to show with a picture than it is to explain so I'll post that below.
Using the tape pieces, the 2 speaker movers will move each speaker into the same colored tape position when the switch is called, and the previous speaker will be moved back behind and out of the way.
I very much look forward to your results! Might be fun to start a forum bet beforehand to see where people's opinions lie. I'll throw my own guess into the mix.
I think the Salon2 will win, and I think it will be very similar to the M2 vs Salon2 blind. The M2 has very similar measurements to the 8351b(both are noticeably better than the Salon2), and the Salon2 beat the M2 by 2 points out of ten pretty consistently. The only explanation I can think of is the wider dispersion.
If it's a mono test I'll say Salon2 90% chance
If it's a stereo test, I'll say Salon2 70% chance
PS: You have no idea how jealous I am of the fact that you own both of my dream speakers that I'm trying to decide between.
Chromatischism
I find soundstage completely collapses in mono, but that is to be expected. Tonality is the same though, and that's what you're listening for. Two speakers should sound tonally the same as one speaker, you just get more of everything.
