The trouble is the sensitivity. Getting an 86dB sensitive speaker to 105dB/speaker(reference level), at say 4m(probably a normalish distance for that speaker), is gonna take quite a bit of power
Luckily, the Salon2 seems to take lots of power quite well. Reference level is also really loud. I doubt many people really want to listen that loud. Finally, boundary gain and having more than one speaker come into play when listening in stereo/multichannel in a normal room, which really helps.
My listening position is at 11 feet so between 3 to 4 meters. When using a calculator, it might be more representative for many to select near walls. Each misestimation doubles the power requirements. My solution was to measure 2.83 volts 0 dBFS sine-wave signals at 250 Hz, 1 kHz, and 2 kHz all were consistent SPL. Two speakers produced 86 dB, a single speaker is 83 dB.
I did this experiment when I received my first AHB2 and drove the Salon2s watching Aquaman with the speakers set to full range.
The woofers were having a workout and the AHB2s (not bridged) were not clipping. This was puzzling.
With 5 speakers, the power requirements seem to be reduced to achieve the loudness levels that me and my family can tolerate.
Having from from ATI AT6002s with 300/450 WPC into 8 and 4 Ohms, I could not reconcile this so I did the experiment to determine my real world requirements.
For anyone concerned, I think it is worth dong some measurements to determine the baseline power requirements.
This table is based on 2 watts driving the AHB2s (bi-amping) since the Salon2s are largely 4 Ohms speakers, so this should be realistic.
For music, I can see how more power is required. For example, if I want to impress folks by playing Awalnation Sail, then I can clip this amps and not get the AT6002 level. For that I would need to bridge them. This is not something I do normally but I have to admit sometimes wanting to
In reality, I suspect that I don't really listen to more that 10 watts with music and movies. Typically, I suspect that I use much less than 1 watt.
One problem with the AHB2s is they have very accurate clipping meters, I suspect if they were off, I would turn them up at least 2 dB more and not notice. At that level., my ears are not discerning.
- Rich
