Connect Audio streamer, turntable, DAC, Amp, speakers
Hi @cube! Welcome to ASR.
Can I connect:
1. Audio streamer (Eversolo DMP-A6) and
2. Turntable (Rega Planar 3 (50 AE)) via RIAA to
2. RME ADI-2/4 Pro SE
and from the RME to
3. Amplifier (Benchmark AHB2)
4. KEF 3 Meta + SVS SB 1000
Or do I need any other device in between?
That should work just fine. No other devices required.
Would the functionality of the streamer and turntable work in parallel choosing the input from the RME?
Not sure what you mean by that. Do you want to listen to both simultaneously?
Thank you for the confirmation!
Not simultaneously, was curious if from RME (the only one I don't have yet), I can change easily the source to transmit to the amplifier from either the streamer or turntable since both of them will be connected at the same time to it.
Sorry for my approximate English.
Thanks!
Yes.
You can connect the DMP-A6 via Toslink and the turntable via analog, then switch between them directly from the RME remote.
