tuga
I have a bias towards towers, but it’s hard to justify the price increase for the F208, especially if you plan on subs.
Not if you listen at loud levels or farfield, unless your sub can cross at 300Hz...
I would like Amir to include in his listening impressions what amount toe-in he uses.
I don't believe the Klippel can show rotated the measurements.
The issue with simulating this with the given data is that it will not 100% reflect the vertical performance, as you can't predict diagonally (whereas the Klippel measures a magnitude of points all around and likely could show the actual performance).
Thanks Amir! Looks like a standout speaker.
Revel M106 ASR vs Harman Spin comparison, corrected the ER curves from the NFS for the Harman-style computation. Omitted the on-axis for graph intelligibility:
View attachment 70865Good agreement up to about 4-5kHz, after which Harman shows about 2dB more energy. I think this has happened with a few of the Revels, I wonder what's up with that, especially after the super-old infinity showed basically perfect agreement.
Edit: And here's the M106 vs the IL10 (Listening Window in white)
You can see the relative lack of energy in the upper mids in the IL10, but idk if enough to explain Amir's different impressions.
Was wondering the same. You get better HF extension, better crossover and more solid drivers. But for an actual sound perception benefit to pay double the money remain to be seen/tested.I wonder what the Beryllium version of this one gets you. Twice the price but they appear to be very similar.
Jbl 530 is a very good sounding loudspeaker in the right room.That SB acoustics tweeter is really cool. It is the one I plan to use in a DIY active set-up (someday)
A Selection of the DIY community hails it as one of the best tweeters essentially ever. (of course not all agree)
Amir you might want to have a close look at it. It is has an interesting design.
I had the baby M105 for awhile. It had a very, very smooth tweeter. Unfortunately I no longer have it. I purchased it to be used as a reference 5.25 inch driver based speaker. I liked everything about the speaker except that I liked the JBL 530 more & it therefore became my 5.25" driver reference.
The one thing about the REVEL M105 was a less detailed bass compared with the 530. I wonder if that has anything to do with the distortion characteristic? The 530 also seemed to have more depth. (maybe) It was deff more articulate in the bass.
Yeahh that’s a total overkill and it’s a great thing. You must be enjoying incredible reference multichannelI've got the M106 for surrounds, maybe overkill
That distortion isn’t really audible, the average person needs the THD to be around 20% at 100Hz. That’s with content playing, with test tones it would be lower, here is threshold for individual harmonics .This is a great post that helps to illustrate why a pair of low sensitivity bookshelf speakers don't have the slightest prayer of coming anywhere near reference level capability. At 9 db below reference(96 dB), distortion is already skyrocketing. We will lose another 6-8 dB for normal listening distance, and another 3-6 dB *easily* for room eq. Also shows why towers are so much better, even with subs, in so many situations.
I don't disagree, but again, 9 dB below reference at 1m without any eq. This equates to 15-17 dB below reference with the 96 dB distortion sweep shown. With 3-6 dB of eq added below 3 dB, which will be nearly guaranteed, distortion will be much higher than the graph above, and we are still 15 dB or more below reference level.Also, I’d like to point out that these are 7-8 years old.
Dont forget that you have the room gain that is, in many cases, about 10 dB ” for free” i the bass register with two loudspeakers being placed in a room.This is a great post that helps to illustrate why a pair of low sensitivity bookshelf speakers don't have the slightest prayer of coming anywhere near reference level capability. At 9 db below reference(96 dB), distortion is already skyrocketing. We will lose another 6-8 dB for normal listening distance, and another 3-6 dB *easily* for room eq. Also shows why towers are so much better, even with subs, in so many situations.
Room gain is usually 6dB/okt with dropping frequency. The point where the gainstarts depends on the size of the room. The smaller the room, the higher the starting point of the 6dB/okt curve.
That harmonics table looks very interesting, thank you.Also, I’d like to point out that these are 7-8 years old.
What I find interesting, is that besides the KEF R3 losing bass output at ~120Hz and the difference of directivity, it is better in most every way by looking at all the graphs, yet even with the room mode correction, the listening impression was not as enthusiastic:
I’m about to spring for F206 for surrounds...I've got the M106 for surrounds, maybe overkill
Sensitivity: 86dB
Frequency Response: +/-2.7dB 80Hz-20kHz
