I am curious, if these measure so well, what would be the point of going with the new beryllium tweeters?
Compare their Spinoramas and point out which major differences you see.Yeah, this formula either doesn't work as had been hoped, or something else is going on. Maybe bias against $118/pair speakers? Doesn't seem to be the case for $300/pair LSR305's.
As more testing is done, this formula looks more and more suspect. The big question is why of course as I don't doubt it matched results from Harman's work. Is Harman leaving something else out or what?
Well, I eq my L/R speakers differently , which results in them being eq'd the same if that makes sense. I don't want my L/R to sound different.Yes but have you ever HEARD differences between speakers EQed the same (or not at all)?
While you definitely can when the EQ applied differ.
Why obviously you need to work on a cure first then. All I'm hearing is excuses Amir.We could do our own listening tests but boy is that a big effort to get enough data points. And with this virus going around, no way to even get started on it.
Likely just Samsung showing their influence.So is there more being left unsaid by Harman? Their sudden reluctance to share with Amir seems like it might be.
There are other factors than frequency response. Distortion, impulse response, etc.I am curious, if these measure so well, what would be the point of going with the new beryllium tweeters?
Well falling apart on loud bass might confirm it. That would be one of the things Harman left out. Make sure your speakers being compared by the formula don't get overloaded in use. I'm also thinking of how Amir responded to the R3 and Genelec vs other speakers he preferred considering the scores they received using the predictive formula. And how he thought more of them (R3 and Genelec) once he EQ'd them.Compare their Spinoramas and point out which major differences you see.
As stated multiple times, stuff like max SPL isn’t a factor, Amir stated the Pioneers fell apart when playing loud bass.
I’ve been adding the impedance and distortion graphs to my spreadsheets, as that also gives you a good amount of information.
Doesn't take into account how loud you can play them. Those Pioneers will break apart at low SPL levels.So, these scored a mere 0.06 above the $118/pair Pioneer SP-BS22-LR, a pair of speakers where a number of owners chimed in to express how little they liked them. Hmm.
The formula is only looking at frequency response, so if you EQ it the score will of course go up. The issue is you can’t just make it perfect, it would have to be a realistic EQ, and even then that’s EQ’ing anechoic data, not your in-room response/experience, which doesn’t just deal with Time 0, but reverberation as well.Well falling apart on loud bass might confirm it. That would be one of the things Harman left out. Make sure your speakers being compared by the formula don't get overloaded in use. I'm also thinking of how Amir responded to the R3 and Genelec vs other speakers he preferred considering the scores they received using the predictive formula. And how he thought more of them (R3 and Genelec) once he EQ'd them.
These speaker threads are large enough I don't always keep up. Maybe it has been done. Does EQ on the R3 and Genelec result in a set of spin results that would score them even higher in the formula?
Oh, and I want to make it clear how much I value the work you and others are doing providing us with the other graphs and data sets. It is a big plus to the forum.
Well the whole, unexpected result of their work, was how rather predictable across various factors and listeners speaker preference was in their testing. That such info about what preference pointed toward allowed them to engineer speakers which would give excellent performance at any given price and level of use. The results of their work in their speakers sure seemed to bear that out.
Is the variability of preference a bias related thing when you know the speaker in use? That would fit with lots of other data. It doesn't however seem to fit with the Klippel based data all that well.
Sure, but are you implying that a large number of people spent money for the privilege of being able to trash a speaker? I was surprised by how few of the speaker's owners defended it, which is what you typically see from people who enjoy something.
What preference? I watch a ton of speaker reviews online these days and none of it makes any sense. Try to summarize a single one for me and you will fail. "It has great highs but not a detail king. The mids are great but a bit recessed. Soundstage is huge but not front to back." Their basis for evaluation is so weak, and so biased to say positive things to keep the loan program going that they make no sense.To me the preference ratings are a bit of a marketing gimmick... And as far as I can see it's more likely that audiophiles will give preference to opinions coming from the likes of Gutenberg, Darko, Fremmer or Dudley than a "measure-ist", rational approach.
The problem with the Pioneers is the 4" mid/low driver severely limits maximum output and bass is missing. They are probably good for a desktop setup, but 7' away they did nothing for me.
I haven't read a review in ages.
My approach for over a decade now has been is to learn how to read measurements and try to correlate measurement them with listening as well as possible. And to educate myself on some of the basic tech.
I actually disagree - Looking at the overall picture of the measurements I'm inclined to think the formula is working pretty well. I don't think they can or should be tied too closely to the impressions of one listener but overall the ones that measure poorly don't sound great and the ones that measure decently do. This is the expected result. AFAIK there hasn't been a speaker with terrible measurements that sounded great to Amir, and again, it's the impression of one listener.
Obviously though, I don't doubt Harman looks at far more things when designing their speakers than whatever has the best preference score. I mean, as far as I know, there's no reason to believe they actually calculate the preference score when designing new speakers - it's all about the blind tests.. But the principles are there.
I’m more inclined to think of these scores like Rotten Tomatoes, where the score isn’t a rating, but a % value of mass preference; a 99% isn’t one of the best movies ever, it could be a solid 6/10, but if everyone agrees it’s a 6/10, then it is an easy movie to recommend. With a 10% rating, that means a few people gave it a positive score, not that everyone rated it terribly, most could have gave it a mediocre 4/10.I actually disagree - Looking at the overall picture of the measurements I'm inclined to think the formula is working pretty well. I don't think they can or should be tied too closely to the impressions of one listener but overall the ones that measure poorly don't sound great and the ones that measure decently do. This is the expected result. AFAIK there hasn't been a speaker with terrible measurements that sounded great to Amir, and again, it's the impression of one listener.
Edit: Perhaps more important to me personally, the preference scores correlate quite closely with my interpretations of the data.
I play this little game now of guessing preference ratings based on the measurements, and I've gotten pretty good at it. And with one exception (the Harbeth), they're pretty in line with measurements I'd consider being great, good, decent, meh, or bad.
It would be interesting to put some sales numbers behind these speakers.
Amir owns Revel speakers and has been exposed to Harman listening training. He is obviously very knowledgeable on their research and design principles. It is not mere coincidence that his impressions match the "formula".
Now go over to an analogue/vintageist forum or a pure subjectivist agora and find out how many own wave-guided speakers with a flat response. They do prefer this kind of speaker but they just don't know it...
Why is there actually no Culmulative Spectral Decay diagram in the "starting post" of the F35 review?
The resonances in the 600-1500Hz range are quite strong and affect all generated frequency response curves.
It would be important to see whether the bass reflex port would again cause massive interference (as with the JBL 705P) or whether it is a driver surround resonance, for example..
