having just listened to f35, f206, and 228be at local dealer...I dont see how any of these measurements showcase what the speakers actually sound like. maybe amir could use his salon 2's as reference for reviews and explain how his reviews compare to his reference. I thought the f35 didnt image nearly as well as f206 or be revels.
Remember, its absolutely impossible for bias to not have influenced what you heard, along with whatever actual and real differences there may have been from factors other than the speakers themselves such as different rooms, different placement, setup, etc etc. Also, there is quite a bit of extension difference between those models which has a large affect on our perception of sound quality. Eq'd the same in room, placed the same, and crossed to good subs(as they should be for high fidelity)....I'd be willing to bet the results in blind testing would be very very close.
That's what I personally find so appealing about the measurements. It eliminates all the inaccuracies and fallacies of sighted demos in stores. Narrow your choices down to speakers that measure really really well. Narrow things down further based on bookshelves mounted precariously on stands or floorstanders, price, aesthetics, and sensitivity, etc. Eq them properly in your room crossed to good subs and you will have great sound. I believe that having the speaker you like better based on brand loyalty and aesthetics will make a bigger difference on how happy you are with the sound than wether you have the KEF R3 or the Revel F35.
