- Joined
- Jan 27, 2019
- Messages
- 7,334
- Likes
- 12,296
A proper home theater needs capable subs. I have 2 subs for movie watching (and music).
Dang. I’ve just learned my 7.0 HT system is improper. ;-)
Easy to fix... stick out your pinky finger while sipping tea and don't slurp... off ya go now.Dang. I’ve just learned my 7.0 HT system is improper. ;-)
How do you manage the LFE?Dang. I’ve just learned my 7.0 HT system is improper. ;-)
I have not auditioned the F328Be. I was pretty irritated that they announced the F328Be literally 2 months after I bought the F228Be. Plus coming from the F208, I did not and still do not like the Be cabinet design especially the F228Be that’s essentially the same size as the F208. Things may have been different if I went straight to the F328Be since the cabinet is larger. Double the price for the same cabinet was a bit of an eyesore.I agree that for home theatre you need the sub. You need it for the LFE, which is where all sub information is. Unless you are watching a concert of Saint Saens Organ Symphony, there is not much going on below 30Hz in film soundtracks' LCR channels that are not in the LFE.
BTW, have you auditioned F328Be? It is in a different league to F228Be.
But the LFE. What do you do with the information from the dedicated x.1 channel (that would otherwise go only to the subwoofer)?I run my L/C/R full range. The center channel in particular is a very large, brawny speaker. With some room boundary gain, there is plenty of deep bass/impact and huge scale for movies. Pretty much precisely as I want it.
Can't you just run the LCR full range and do nothing with the LFE?But the LFE. What do you do with the information from the dedicated x.1 channel (that would otherwise go only to the subwoofer)?
LFE is a separate channel. There is signal on it that does nor exist on other channels. You have to somehow hear what is on it, don't you? Not feeding LFE to any speaker is like not feeding centre channel to any speaker.Can't you just run the LCR full range and do nothing with the LFE?
Well, yes. That is the question.Can't you just run the LCR full range and do nothing with the LFE?
When I did surround, the AVR's could be set up to send full range (incl. LFE) to speakers of your choice.LFE is a separate channel. There is signal on it that does nor exist on other channels. You have to somehow hear what is on it, don't you? Not feeding LFE to any speaker is like not feeding centre channel to any speaker.
Then your solution is to use bass management. Not using the L/C/R just full range but adding LFE to them.When I did surround, the AVR's could be set up to send full range (incl. LFE) to speakers of your choice.
Well. You might be right. But as I interpret full range it is incl. LFE because that is the full range of the signal from the movie.Then your solution is to use bass management. Not using the L/C/R just full range but adding LFE to them.
There are individual channels, each one has separate signal. Other than LFE they are full-range but LFE is limited to sub frequencies. That is why bass management is invented.Well. You might be right. But as I interpret full range it is incl. LFE because that is the full range of the signal from the movie.
But I bet there will be quite some room modes activated and not tamed?I run my L/C/R full range. The center channel in particular is a very large, brawny speaker. With some room boundary gain, there is plenty of deep bass/impact and huge scale for movies. Pretty much precisely as I want it.
There is a trick if you do not want to use a sub but that you do want the use the LFE information.But the LFE.
Yeah. But LFE is part of the full range. AVR setup can be made to send all signal to whatever speakers you want in the menu. Typical you set your L+R to LARGE and if you tell the AVR that no sub is present it will send LFE to all speakers with the LARGE designation.There are individual channels, each one has separate signal. Other than LFE they are full-range but LFE is limited to sub frequencies. That is why bass management is invented.
Well to be honest (tbh) I didn’t consider someone having all full range speakers let alone those full range speakers having enough output to not require subs .Yup.
That should be common sense. For movie playback, all sorts of scenarios are presumed, including that many/most people won't have subwoofers. Which is why
the low bass frequencies can either be sent discretely to a sub, if present, or only to whatever loudspeakers someone is using.
(I just had a friend over to watch A Quiet Place - hadn't seen it yet. All the dynamic moments, the giant footsteps included, where huge, with deep feel-it-through-the-floor bass...because the low frequencies were simply sent to my L/C/R speakers).
